Used SMC Enterprises 2002-2005 Subaru WRX Alcohol Injection System plus a gallon and half of Boost Juice (Snow Performance) Methanol/water mix. $200 ref:
http://www.smcenterprises.com/subaru.htm
Wilwood forged four piston Dynalite calipers with brackets and Stainless Steel brake lines for use with stock (02-03 WRX) size rotors loaded with Polymatrix Q pads will include two sets of extra pads Q and E compounds. Will fit under 16" wheels great for you rally guys. Upgrades are available to up rotors to 13" or two piece rotors from www.revolutionbrake.com. $400 Will also include a MRT master cylinder brace and EBC very used rotors. pictures in following post
New in box KAKUMEI 02~03' WRX Bug Eyes Impreza Reverse Hood Scoop (FRP) $100 ref:
http://www.ttnet.net/english-site/si...refno/3658368/
AIM MXL Strada digital dash with fuel pressure, oil temp, Speed, RPM, Water temp, and EGT sensors and harness $1000.00 ref
http://www.aimsports.com/products/mxl-strada/index.htmlpictures in following post
Used 02-03 Bug Eye headlights in great shape $100
Used JDM STI rear lateral links with sway bar end links silver $150
The black stuff is under coating over spray
Set of four SSR GT-3P three piece wheels 18x9 5/114.3 with Goodyear Eagle F1 tires 255/35/R18 $2000 all in new condition. Or trade for a an set of Gold BBS 08 STI wheels with tires
Momo race Air carbon fiber shift knob and e-brake handle $50 for both
Oil cooler 11" x 3" with 10an fittings, remote oil filter adapter 10AN fittings with Canton billet oil filter, Mocal sandwich adapter with internal thermostat 8AN fittings, Oil cooler 11" x 5 1/2" with 8 AN fittings, AND 1qt. breather can with 10AN fitting $150 for all of it. pictures in following post
2qt Dry Sump oil tank billet aluminium $100
Tilton oil pump $100
03 WRX door cards $10 each LF RF available
Window Glass from 03 WRX Wagon tinted 20% Doors LF LR RF RR , Rear Hatch, Rear Quarters L&R $20 each
Hydraulic handbrake $100
Spearco inter-cooler $150
PnP Intake manifold off an 03 WRX set up for reverse mount with PnP & knife edged Throttle Body $50 painted light blue.
Lots of pictures in link here:
http://forums.nasioc.com/forums/showthread.php?t=1694862
Dave Potter
Potter Racing
PHA #139 S3
“There are only three sports: bullfighting, motor racing,
and mountaineering; all the rest are merely games.â€
• Ernest Hemingway
http://biknman.shutterfly.com/action Link for my photo album
Enjoy
Edited 3 time(s). Last edit at 02/13/2009 11:09PM by biknman.
