The THs are sold. Going to order a pair of 15X6 MO wheels for the front and keep the 15X7 for the rear (which fit fine on the rear).
I'll sell 2 of the MOs with brand new Yoko gravels, kept inside in windowless room and temp controlled since new, for $400. This would work on the back of any Merkur.
If you look at the Sierra setup sheets you'll see that Ford ran larger wheel and tire widths in the rear. This is probably quite good on the Merkur too. I've decided I'm keeping four of the MOs I have to run in the rear. Two I will sell. Then I'll order four 15X6 to run up front on a slightly skinnier tire.
For the TH2 17's, again, they fit fine in the rear, just need the one inch spacer in the front (if using JVAB coilovers). So there I'm going to buy a pair of 16X5.5 TH2 wheels for the front of the car. So if anyone wants to buy two of the TH2 wheels, the two that are literally brand new and less than 5 miles on them, with Yokohama street tires, I'll sell those for $500. Again, sweet on the rear of the Merkur, don't fit with JVAB coilovers in the front though. Should work fine though for stock Merkur.
Edited 1 time(s). Last edit at 09/28/2007 02:07PM by NoCoast.
