ElectroTech
Steve Wheeler
1992 Golf
Re: Snow rally dampers setups
November 25, 2015 01:49PM
ElectroTech
Another issue to consider is ice buildup on the shaft and if the dampers have provisions to deal with it. If there is not some form of scraper before the seal then ice will tear the seal up or let moisture into the body and also let the gas out. Some form of shock/spring cover is needed if that is not accounted for in the seal design.
Yeah the top most seal is a scraper seal...
For dust or ice?
What weight oil is in the Soooper Bitchin setup?
I'd be looking for some way like neoprene to keep heat in the shock body.
Snidewhips
Jeremy Livingston
1990 acura integra, 2010 Hyundai Genesis Coupe
November 26, 2015 01:18PM
so far my hotbits minus rear sway bar on two over soft jounce and rebound have been setting the car nicley on snow and ice with all seasons on of course i have a slow fail wheel drive. spring rates are 220
All bridges burnt, island life is beauty
lelikmed
Alex Kuklov
2000 RS
November 26, 2015 09:15PM
John, a lot of technical information.
Do you make a spefic snow/ice setup with your shocks?
Edited 1 time(s). Last edit at 11/27/2015 09:52AM by lelikmed.
