Closeup component pics from WRC Spain
Posted by pikespeakgtx
Re: Closeup component pics from WRC Spain
November 05, 2008 03:29PM
Threadjack!? Are you joking? You guys talking adds way more value to these threads.
If you can get Tim talking about cool shit then who cares!?
November 05, 2008 08:56PM
OK then, Tim is t304 SS schedule 10 what mere mortals should be looking at for header/down-pipe fabrication?
November 05, 2008 09:23PM
> fabrication?
The schedule 10 butt weld fittings (like these: http://www.acestainless.com/index.php?act=viewCat&catId=75) will work for quite a while. They will not last anywhere near as long as 321 though (right here: http://www.burnsstainless.com/321tubing/Ubends321/ubends321.html). It eventually comes down to how much you are paying for labor. With the difference in the price of the bends you can do at least 3 manifolds out of butt-weld elbows for every one in 321 mandrel bends. How much is your time worth?
Lurch
Eric Burmeister
Mazdaspeed3 and Mazda Protege
November 05, 2008 09:57PM
Yeah, that's what we used (the sch. 10 stuff).
Lurch
Eric Burmeister
The west coast...of Michigan
open | download - DSCN1284.JPG (186.3 KB)
Lurch
Eric Burmeister
November 05, 2008 10:15PM
wrong photo.
Lurch
Eric Burmeister
open | download - DSCN1614.JPG (75.2 KB)
WRC Corolla Inconel photos
November 11, 2008 12:54AM
WRC Corolla Inconel Shots...
Parameters:
General: Made by manufacturer, Year: 1998
Weight: 1230 kg
Engine: 300 LE, 550 Nm
Gearbox: 6-speed, sequential, make: X-TRACK, with active front differential
Clutch: 7-plate carbonic SACHS
Running gears:
Front McPERSON ÖHLINS shock absorber, 3-way adjustable
Rear McPERSON ÖHLINS shock absorber, 3-way adjustable
Brakes:
Asphalt
Front 343 mm and 370 mm brake-wheels, AP working cylinder, 4 brake-pistons
Rear 295 mm brake-wheels, AP working cylinder, 4 brake-pistons
Gravel
Front 295 mm brake-wheels, AP working cylinder, 4 brake-pistons
Edited 1 time(s). Last edit at 11/11/2008 12:57AM by pikespeakgtx.
open | download - toyota12.jpg (117.2 KB)
open | download - toyota11.jpg (81.8 KB)
Re: WRC Corolla Inconel photos
November 11, 2008 01:04AM
one more with the cover off
open | download - corolla inconel.JPG (44.6 KB)
Bruce Beauvais
Bruce Beauvais
none- right seat's for me
November 25, 2008 11:02AM
> Parameters:
> Weight: 1230 kg
> Running gears:
> adjustable
> adjustable
> Brakes:
> Asphalt
> 4 brake-pistons
> Gravel
> 4 brake-pistons
> 4 brake-pistons
> Michael LeCompte
> Edited 1 times. Last edit at Nov 10, 2008 by
> pikespeakgtx.
You didn't mention the very special intake restrictors. smiling smiley
Bruce Beauvais
Too many SAABs to count
November 25, 2008 11:39AM
I thought it was the Celica with the special restrictors
