Re: To all those with Suspension on order from JVAB
November 21, 2012 09:42PM
John, messaged you some measurements. Called your phone till I was blue in the face, then realized you are overseas.
Keep trying and I'll answer eventually Messaged me?
Post them here cause of email log in problems
Message as in forum private message you dingbat winking smiley
24" eyelet to eyelet extended
15.25 full compressed
skinny shaft 11mm in diam
50mm body
If I may quote myself "Doh!"
Chris Krepski in Gatineau and Marc-Andre Larose in Rougement Quebec
December 04, 2012 09:34PM
Here's some stuff that should make you happy:
and these are heading to the secret rendesvous:
Those E36 things:
Next boxing and sending Toyota, Volvo, Fuck-us...making more Subie ears.
Oh, all those waiting on snooze on the JVAB 50s...things are happening---down till 12 last light sawing the chunks to make the spring seats and locking rings...
Re: Chris Krepski in Gatineau and Marc-Andre Larose in Rougement Quebec
December 04, 2012 11:53PM
Great work as usual John. I will probably pull mine for you to look over after abusing them for a couple days this month. May go ahead and do what we talked about.
rally864
Erik Hill
ZX3 Focus (Building)
December 05, 2012 09:10AM
John could you post a picture of your focus dampers?
thanks
December 05, 2012 09:16AM
how would the 40mm work out if i wanted to do some tarmac use in the Merkur? Should i opt for a second set optimized for broken pavement (hillclimbs)
December 05, 2012 09:31AM
They will be fine on a hillclimb with less than smooth pavement. Just put yur sway bars back on
December 05, 2012 09:46AM
rally864
thanks
There's some here I think
http://www.rallyanarchy.com/phorum/read.php?5,40301,40352
December 05, 2012 02:21PM
Is that BMW top mount off centered? Would correct camber easily? I think Derik's Reiger's are offset and maybe a good starting point?
December 05, 2012 02:24PM
I gotta get JVL some pics of my car. We talked about it last weekend when I was down at the shop, but given the small hole in the BMW strut tops, to be actually worth doing, that hole may need to be opened up some.
December 05, 2012 06:30PM
Yeah, the Reiger top plates are offset a bunch. I just aligned his car again last night, at rally ride height it is -.9 degrees camber in the front, 6.5 degrees caster. Ther rears I set to -.25 camber at ride height.
I am pretty sure he is running standard 325 front knuckles, and M rear arms.
Edited 1 time(s). Last edit at 12/05/2012 06:31PM by phlat65.
December 05, 2012 06:40PM
Yeah, the Reiger top plates are offset a bunch. I just aligned his car again last night, at rally ride height it is -.9 degrees camber in the front, 6.5 degrees caster. The rears I set to -.25 camber at ride height.
Damn, that's some pretty good negative camber up front! Any chance you know the front ride height setting or you managed to take some pictures? smiling smiley
December 06, 2012 12:34AM
He runs the car pretty low, It is probably 1" over stock at the most.
Re:Vaugh Gittin this is packed and ready---finally.
December 09, 2012 07:07PM
And I even uploaded piccies:
Will email with totals.
Next up is some Fucci, and Beee Ehm Wubblewoo
December 09, 2012 07:37PM
As in mr pony car drifto dude? For this car?
http://www.speedhunters.com/2012/06/vaughn_gittin_visi/
About halfway down the page.
Zap zap my ass...
Edited 1 time(s). Last edit at 12/09/2012 07:41PM by slidewayswrx.
John Reed
John Reed
Toyota AE86
December 09, 2012 07:50PM
Feel free to ship those HA-CHEE struts to Portland and I will hand deliver them. Someday...... winking smiley
Is that what you were talking about doing to mine, to convert to two bolt?
John Reed
John Reed Racing
www.johnreedracing.com
johnreedracing@gmail.com
