Helical VS Clutch Type Differentials?
Posted by Carthik
Re: Helical VS Clutch Type Differentials?
August 24, 2012 12:26PM
It's such a shame that so many people make great diffs for the Ford 7.5" differential but nobody makes a reasonable final drive. I could probably stomach spending the dough for a Gripper or Drenth differential if I didn't also need to spend another $2k for a decent final drive ratio in the stock Merkur differential.
Side note on Drenth and Kaaz. A friend here in Colorado continually had problems with the Kaaz in his VW 020 gearbox. I think there was 2-3 DNFs related to it. He got to the point where he was about to just spend the $9k or so on the Drenth box and call it good. He then decided it was smarter to swap to the 02A or J or whatever the newer box is called. I think it was around halfway through the swap where he decided racing mountain bikes fast through trees was also super fun and he didn't drive halfway across the country and spend 5 days and a few grand to race only to end up with a mechanical problem on the first few stages.
I think I'll be able to convince him to buy a BMW once he spends a day in Dave's Compact or the 325i I'm starting on in about 20 minutes.
August 24, 2012 12:39PM
there are 7.5" final drives at 4.27....but they're rare and pricy and the whole cost escalates drastically...post from UK, bearings, seals etc.
What did you pay for the Supra complete units you have?
krisdahl
Kris Dahl
Integra, Civic
August 24, 2012 12:41PM
If you have a D-series (limited options), and especially if you're just starting out and don't want to spend a bunch of money, I'd put a spool in or weld the diff.
I use KAAZ diffs in my Civic and Integra, and they handle well, good grip, but I dont' have them preloaded enough to be able to drive out on a busted axle or anything.
Nice thing about the welded diff, is it is pretty cheap, handles pretty well/consistently. Downside is you'll have to change your driving style a bit to adjust for the corner entry understeer you're going to experience.
August 24, 2012 07:28PM
I know. I've seen them occasionally. And a 4.56 that was only like 1000 GBP. That's what I was saying, if there was a decent CWP for cheaper, I would have considered something like a Gripper. But yeah, becomes a $3k diff pretty quick.
Supra diffs, 60, 60, and 45, the latter needing bearings/rebuild. All 4.3.
tmachnik
Tom Machnik
1985 VW GTI
August 24, 2012 09:26PM
I absolutely love my gripper, worth every penny
August 26, 2012 07:36PM
Not related to the 7.5" used in V6 Thunderbirds? ('89-whenever they made the 8.8 standard)
Summit shows 4.56 and 5.13 gearsets for those. http://www.summitracing.com/parts/RMG-6903481/
Is there any stage experience with the diff, forget its name but it is a helical that has clutch packs to give some preload? I've seen a Golf with one driving around with one axle.
August 26, 2012 07:40PM
Shoulda said Euro Ford 7.5.
No relation to anything else in Ford's US lineup.
AlexeiS
Alexei Stapinski
1991 Suzuki Swift
August 29, 2012 08:59AM
This is probably a dumb question, but while we're talking about clutch diffs and Grippers, what's an ideal breakaway torque to set it at? When I talked to Gripper, they suggested 60 ft lbs for gravel rally and that's roughly what I set it up at on the bench (with the assembled diff lubed up with gear oil). I have to try it now with 2 - 3 events on it, it may be less after a few events.
Supposedly the Swift currently puts out around 100 ft lbs at the wheels on the dyno, so unless I'm an idiot setting it much higher would almost mean it never breaks away, right?
I'll say that so far Gripper support has been good. I got a rebuild kit from them and they included an upgraded redesigned cross pin with it at no additional cost.
August 29, 2012 09:16AM
AlexeiS
Shiiiirly 1st 2nd and 3rd gears will put down a bit more than those 100ftlbs.
That being said, too much preload also creates different handling characteristics/problems that need to be dealt with in conjunction with suspension geometry, like more caster for weight jacking purposes and witchcraft like that.
I did a quick search for some diff setting explanations and this reading has some explanations on it http://www.intothered.dk/simracing/differential.html
AlexeiS
Alexei Stapinski
1991 Suzuki Swift
August 29, 2012 10:07AM
*smacks head* I am an idiot after all tongue sticking out smiley I knew there had to be other things like that or when the power is on vs coasting and crap. Thanks for the link, that looks like a good read. Bookmarked for the next time I pull the diff out.
