Front wheel drive Vs. Rear wheel drive
Posted by rallyspecV
eyesoreracing
Dave Coleman
Mazda3, SE-R Spec-V, 510
Re: Front wheel drive Vs. Rear wheel drive
July 24, 2007 04:40PM
Scott Manley Wrote:
> eyesoreracing Wrote:
> > off the pedals, and hope the heavy end gets
> to the
> > end of the corner first.
> Maybe start with a better balanced car. My XR has
> a near 50/50 wieght balance. It doesn't handle
> like that in the corners.
> Scott Manley
> Spokane, WA
> 86' XR4Ti
> 32
Doesn't handle like what? Won't straighten out if you overcook it and end up sideways? Doesn't get sideways? You never overcook it?
-Dave
July 24, 2007 06:40PM
I have spun my AWD, RWD and FWD rally cars more than once. The biggest one was in the AWD car when I lost it big time on a f'ing straight... I can report they all spin just fine, even FWD with the foot firmly pressed on the go faster pedal.
How very true about FWD not working till 8/10 + however, and I agree FWD is farily stable and not all that intrested on looping unless you lift - never lift in a turn.
July 24, 2007 07:51PM
FWD is hard to spin?
FWD sorts itself out?
News to me!
FWD *is* easier to drive fast, 'cause you only have to flick the car around as a convenience (how quick can you turn the wheel/how much do you hate your CVs). But you can definitely spin 'en, and mashing the throttle doesn't always help...
wildert
Brian Klausen
VW Golf GTi 16V
July 25, 2007 06:45AM
That pretty much sums it up for me to. Currently driving a Mk 2 Golf, I'm serious fast when I really get a hold of myself, my balls and wrap my mind around the "I can't die"-mantra. Sadly I'm not good enough at that, so there's too long between me being serious fast...
And yeah... don't lift in a turn! At least it's true for Golves... :-).
I have previously owned a Mk 2 Escort - and the Golf is just better for me. Sure, having the rear hang out was a bit of fun, but I'm obsessed when it comes to racing lines (we're on tarmac over here), and the FWD Gold just works better for me in this aspect. Also, I trust it more...
Brgrds
Brian
randyzimmer
randy zimmer
rallycross 13B Miata
August 28, 2007 11:02AM
JV is already pissed at me for supporting a capitalist so what do I have to lose.
I vote 4wd.
(I can hear the BOOO! already)
I went RWD at RWVa and the car drove great and the times didn't suffer too badly.
Starts were painful as were uphills out of hairpins.
I spun once adding too much gas too soon in 2nd.
3rd gear and up drove the same as I'm used to.
Broke an axle on one of those uphills and got a tow back and switched to FWD but Rusty wanted to bail so we quit.
(he has some sort of sickness {that hasn't been diagnosed} I was unaware of before we went)
I was kind of interested in a back-to-back test but not too sure it was prudent - we already got one tow back. Rusty decided for me.
RWD was very expensive over 4wd.
To finish the rally we would have destroyed 6 rear tires that would have lasted two events each in 4wd.
To make it bulletproof would cost a grand for a good big diff, big axles and hubs to fit.
Not cost effective just to finish 3rd/4th in MaxAttack.
DNF cost, tire cost, waste of good axle = 4wd for me.
August 28, 2007 02:48PM
> I vote 4wd.
Randy, I ain't pissed at you fur nuthin. I'm not even pissed that you drive a Sub-a-rat. If everybody approached the sport as you have there'd be more guys staying in, you've done it the reasonable way.
And wha's diz about supporting a capitalist?
I'm a fawkin small time guy slaving over a hot lathe making soooper bitchin 50mm suspenders because I'm not a good enough capitalist.
We all need Capital.
(We don't need Imperialists tho, or no checks over unrestarined capital; accumulation)
> hairpins.
Might that have to do with the total absence of either horsepower or torque from the wheezy (I've driven stockers) 2.5 NA motor?
Yep.
> bail so we quit.
> 4wd.
> MaxAttack.
> me.
Well that's because the rear diff at 160mm is a poor joke, and the axles weren't ever intended to be rwd ONLY, blame yourself.
My stock Ford 4x4 front diff is bigger than that, stock rear is 190mm.
You only proved what you probably knew already.
gilbrock
Eli Gilbert
91 Galant, 02 WRX
August 28, 2007 04:08PM
I do wonder, however, if you DID beef up the Subaru for RWD, with the right diff and axles, how it would fare against some of the MaxAttackers?
turoc
Ozgur Simsek
working on a Veedub
August 28, 2007 05:59PM
I believe Randy was running 2nd amongst maxattackers right between Kyle and the Wimpey boys. With the misfortune of both it probably would have been a very very close podium.
Please note that there was only a mere 22 second or so difference between Sarasin and the Wimpeys
randyzimmer
randy zimmer
August 28, 2007 06:49PM
> > hairpins.
Oh yeah, sitting on the starts and following the big guys going thru 5 gears and spinning all the way when we bog and wheeze thru 1-1/2 gears in the same section is painful too but I'm used to that.
Having the rear wheels slip and slide and the car going absolutely no where is even MORE painful. I was doing starts like on ice and it still wouldn't move. Now I had TOO MUCH! power.
> > MaxAttack.
Yeah, I could have went out and found an old STi rear end setup but I was hoping to make it thru one event - maybe - and had the front set up along if I could have limped it back. I more expected chipping a couple teeth or having some big clunks rather than a clean snap of the shaft that left us dead in the water.
> John Vanlandingham
Well, it was a good experience and I didn't waste too much money on it. The car was probably capable of beating Lurch at the rate he was (not) going but between Rusty being rusty, me pulling the intercom wire apart a few times and not listening to Rusty when he was right, we should have just been able to stay ahead of the TypeR for 4th.
If someone wanted to do it again, I think it could work with some more prep and a couple bucks for some bigger stuff.
Josh Wimpey
Josh Wimpey
Sneak the Golf
August 29, 2007 09:58AM
Actually, we had a 1:44 lead over Randy after Fridays stages and were quicker on every stage....
One. Class -- 2WD
www.quantumrallysport.com
