WRC Deaths
Posted by darkknight9
Re: WRC Deaths
September 26, 2013 11:02AM
mulik52
I find it interesting how a lot of points discussed and argued here are explicitly shown in this mounting instructions: https://www.schrothracing.com/sdocs/2009_Competition_Instructions.pdf
The pics on page 11 show clearly that belts stretch a lot (therefore you want shortest possible belts as even in that configuration there will be a lot of give. And you certainly want your belts to stretch, irregarding the timing of peak deceleration, as having bells stretch will necesseraly reduce the total energy which needs to be absorbed by the body. But if they stretch too far then you hit the steering wheel defeating the point of the belts). The pics also show why one might want to wear Hans device, look at the motion of the head without hans. Finally, they explicitly state that shoulder harness should not be mounted below shoulder levels, or spinal column compression will result. As someone pointed out, Hans will exacerbate this requirement, potentially explain all those spinal column compressions.
Klim
Tavarich Klimsli, the page 11 shows "scary pictures' and that is the intent and that is all it shows. No Data at all therefore NOTHING can be concluded..
I think you have just show the "fallacy of "logic'.
In other words it shows something "true" ie "belt stretch" but no data to make that information useful.
We have no idea of weigh of the dummy, rate of deceleration, type of "barrier" length of belt, material of belt, nothing really but scary photos.. And your conclusion should be tempered to something like "below shoulder...MAY result in" since reality has shown us over the years that many people have crashed with harnesses below shoulder without spinal injury. (I was always told it would injure shoulders)..
Belt stretch should be expressed in % of stretch per length ie 2%/foot or something like that.
mulik52
Klim Verba
Audi 90Q 20V n/a
Re: WRC Deaths
September 26, 2013 12:20PM
Comrade John, please refer to Page 9 of the same brochure:
90 degree head on collision
75 kg dummy
50kph
Stopping distance of 400mm
Peak of 30g
klim
Re: WRC Deaths
September 26, 2013 12:49PM
So, using the hypothetical number above, a 2 foot belt would stretch 4% and a 14 foot belt would stretch 8%? Wouldn't 2% be 2% regarless of the belt length?
Re: WRC Deaths
September 26, 2013 01:07PM
Wow, you're good with math.
That's how % works. 2% is 2%....
danster
Haggis Muncher
VWs (for my sins)
Re: WRC Deaths
September 26, 2013 01:19PM
Easy guys, I best nip this in the bud, the full moon was last week, get a grip of your hormones and menstrual cycles please, potentially they are running seven days retarded. T'internet is already full of shit this week. There's no more room available for pedantically splitting hairs please. grinning smiley
Re: WRC Deaths
September 26, 2013 01:27PM
Shelve the attitude John - I was asking a question so I could get some clarification on what you were saying. Which is why I asked the question.
Your initial comment was that the stretch should be indicated in % of stretch per length... The only reason to have 'per length' would be if the percentage of stretch increased with the length of the belt - otherwise straight percentage of stretch is all that is needed.
2% stretch of a 4 foot belt means it becomes. 4.08' long, or it gains .96 inches.
4 x 1.02 = 4.08
2%/foot of a 4 foot belt means it becomes 4.32' long, gaining. 3.84"
4 x (1+(4*.02)) = 4 x 1.08 = 4.32
The suggestion seemed to be that the percentage of stretch changes with the length of the belt, which I found odd.
danster
Haggis Muncher
VWs (for my sins)
Re: WRC Deaths
September 26, 2013 01:55PM
Fucks sake, don't over analyse this or the rule makers will notice this discussion on the web. You really don't want the FIA thinking to deeply about this or the can of worms will be well and truly opened.
I mean, even with my current drunken grasp of physics, mass, momentum etc surely "belt stretch" is going to be a variable based on the velocity of impact and the body mass of the crashing occupants of the car, not a constant.
This being the case only thin lightweight people will be allowed to drive fast using propriety and currently acceptable belt standards, and fat dudes will either have to drive slower or pay for a more expensive belt to cope and give an acceptable level of restraint when compared to the thin guys in a similar accident.
I think that is fair, or maybe the specifications regarding the proximity of roll cage, steering wheel, etc, to the occupants could be a variable dimension based on their bodyweight to compensate for "belt stretch"......
Ferdinand
Ferdinand Trauttmansdorff
Re: WRC Deaths
September 26, 2013 02:13PM
danster
Mass, definitely. But not velocity.
A relatively slow impact into a fixed barrier might be much more dangerous than a high speed impact through a haystack.
Sudden and large change in velocity is what's dangerous, i.e. acceleration/deceleration.
danster
Haggis Muncher
VWs (for my sins)
Re: WRC Deaths
September 26, 2013 02:29PM
Ferdinand
danster
Now I have already admitted to being DUI (drunk in charge of a keyboard whilst under the influence), and have also managed to pack in another fine glass of wine since I last posted, so my grasp on reality is a variable and most likely slipping. But surely Newton's 2nd law of physics comes in to play here?
Ferdinand
Re: WRC Deaths
September 26, 2013 03:01PM
danster
Correct.
F=ma
The Force applied to the belts is proportional to mass times acceleration.
Speed (velocity) is not what kills. It's change in speed (acceleration), particularly if it's a large and sudden change.
Re: WRC Deaths
September 26, 2013 04:19PM
Ferdinand
And that's why we have restrictors! They limit acceleration right?
Okay, so 2% stretch, that means we're all fucked in a very short time period.
2 ft*1.02 = 2.04. It's only a matter of time until it's 3 feet and you're dead. That reminds me of a band called Anal Cunt. As I recall, every song was like 5 seconds long and ended with the lyric "you're dead."
Re: WRC Deaths
September 26, 2013 05:32PM
4 x 1.02 = 4.08
4 x (1+(4*.02)) = 4 x 1.08 = 4.32 OR a little over 8,12mm longer--if the 2% figure plucked out of the air as an example..
Only to you... eye rolling smiley
Re: WRC Deaths
September 26, 2013 06:24PM
Only to you... eye rolling smiley[/quote]
So help me then.
You said "Belt stretch should be expressed in % of stretch per length"
Why does 'per length' come into it at all?
Or did you misspeak when you said that. (and it really is OK if you did)
Iowa999
no-one of consequence
Re: WRC Deaths
September 26, 2013 08:01PM
Keith -
He's claiming that it's non-linear, which could easily be true. There's no freaking way that it's anything like X%/foot, but it's almost definitely not a simple percent, either.
edit: I find John's participation in a discussion of belt-stretch to be amusingly appropriate in the extreme, given that it isn't acceleration that matters, but the next derivative above, which is known as "jerk"
Edited 1 time(s). Last edit at 09/26/2013 08:04PM by Iowa999.
Re: WRC Deaths
September 26, 2013 08:18PM
Iowa999
Agreed, but the non-linearity shouldn't be in the length of the sample should it?
Clearly more stretch with more force applied and I could see stretch under a jerk load being different than the same load applied over time. (I've seen enough tow straps break)
Also, he did quip back that 2% was 2% ...
