KTurner Kevin Turner Mod Moderator Location: Newark, DE Join Date: 01/27/2006 Age: Midlife Crisis Posts: 364 Rally Car: 2wd Impreza... dude you should do an sti swap |
Aaron Luptak Aaron Luptak Mega Moderator Location: SLC Join Date: 02/15/2008 Age: Midlife Crisis Posts: 776 Rally Car: Civic... |
interesting. iirc, breakaway torque on mine is < 60 ft/lbs, and it's marginally drivable on a broken axle - it's finished 3 or 4 cone squishing runs on one axle, and drives around the paddock well enough. reverse just spins (since it's "1.5 way"?), and driving onto the trailer is a no-go though. KF7RWG http://www.utahrallygroup.com |
The gear to pinions and gear to plates is same tooth count as opposed to the change seen on the Kaaz? What about some discussion on differences between ramp angles and 1, 1.5, and 2 way stuff. Pics would be cool. We're going to rebuild and shim a few Supra diffs with the Weir stage 2 kit that should give around 250 pounds breakaway torque in coming weeks. Hoping the clutch plates and such are decent and reusable though we have four or five differentials to mix and match to build a few good ones. http://www.weirperformance.com/maxgriplsdkits.html Grant Hughes |
In my 500+ whp Evo (no lawyer mandated straws in Colorado) rear diff I've used the a Cusco 2-way, a Carbonetics 1.5-way, a stock 8 plate diff (2 plates are installed backwards for the US spec cars so they don't lock as hard), and a ShepTrans re-shimmed 12 plate diff.
Cusco and Carbonetics both blew to bits in under 500 miles, the stock one didn't lock hard enough for my liking, and the re-shimmed with 12 plates from Shep has been the cheapest and most reliable while still letting me steer with the throttle. (Full disclosure - Shep has been my trans & diff guy since I bought the car and for 3 or 4 seasons as a sponsor.) I think retail on those rebuilds is ~$400 so IMO, not a bad deal at all when compared to the $1000+ Cusco and Carbonetics options. Dave |
Good, but more important is they have an angle on them like modern splines... Look at all kinds of ancient shit and the splines are square form.. Like on my saab where everything was designed in the 40s and 50s. Or Fords aold inputshaft on clutch where the disc sits---or even the fist version of Ford's MS904x4 box, square form and 10 splines. Look at stuff from the 60s from Germany: 30o "pressure angle", or 60o total, then nicer stuff like more modern Fords: 45o or 90o total.. Square always generates a huge stress at the corner, right where the lug sticks out of the disc, and that's where all old school diff plate begin to die. And the Kaaz, trying to get tons of friction area with all those super thin plates and discs, creates a problem from just too thin material. So sure if all the ears stay on for a while there may be more friction area and whatever, but fat lotta good that does when all the ears are floating around in the gearbox The spline style is also good in that as you say more is better but spline type means that the "lug" part can be lower and that means either more area for a given disc diameter or same area and a bigger hole for bigger side and planet gears---which is a big deal inside modern FWD gearboxes which frequently have very very small diiffs---and no way in the world to up the diff size (like those lucky bastids wif Real Wheel Drive who can zot on a few tabs and shove a big axle under their car without fawking with any of the rest of the car.)
No shit, they do and to me, and considering the delays and the price, too frequently...
Sit down and actually measure the diffs. and check splines. PREVIOUSLY back in the mid/late 80s, ring gear bolts pattern, bearing position and everything else was same from 1200 Civic day one to 2,2liter Quaaludes, and all the heroes said "Yo! Dooooooooooood, this fits only blah blah blah--and you don't want a clutch plate diff (delivered with around 45 ft/lbs breakaway) it'll like rip the wheels right out of your hand and stuffs mang. Its certain death!!!! he's saying this to my friend who had sat and measured everything we together could think of and who the evening before had driven the mighty Saab V4 with around 110-112 ft/lb breakaway and loved it and I was on the extenion and we're giggling like schoolgirls (woooooo oooo certian death!! Teeee heeee!!! I'm afraid!!! tee heeeee)
Yeah it's a Gripper. The seem like good guys when i spoke to them when they came on the market..they listen..maybe they could say what if anything is the differences and if that is a deal killer...I'm not the smarest guy but I do know a lot of mechanical type junk and stuff and being old I've seen old stuff and they way that manufacturers solve problems. When I say the spline form ears, espeically the outer ears it was one of those damn that is fawkin smrat! oments. It shows some good thinking about a decades old problem that everybody else just kept on keepin on..
I think Kevin just above had loads of fun with them, I know Service nazi Robert was waiting for a couple of ring gear bolts for Tom buress VW box where they made up their own bolt size and head size--smoooth move. Grrrrrrrrrrrr! John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Tom B Tom B Mega Moderator Location: Douche Canoe, WA Join Date: 02/27/2006 Age: Midlife Crisis Posts: 780 Rally Car: VW Golf |
DO not get a KAAZ for vw unless you have to. Or you never want to rebuild it, 2 times I have had to wait 4-6 months for parts.
Naw, those wimpy ass little springs are wimpy ass little. A nice simple indestructible belleville spring would be way cooler.
The OS Giken one is neat in a way - springs to create a bit of inverse preload (takes a bit before the ramps start to work) so that it can have good locking ability but still turn with power off. Preload comes in with bellville washers on the ends like normal. Have a friend who runs one in a roadrace car. No idea of rally durability or necessity.
My experience with OS Giken: I have installed 2 in an autocross Honda S2000 for a friend, and the first one tore all the splines out of the center section in 3 events, which also ruined the stub shafts, and now the second one has self destructed. The second one was a suposed re-design for added durability.
WishboneRacing Pete Pollard Senior Moderator Location: Richmond, CA Join Date: 06/28/2012 Age: Possibly Wise Posts: 11 Rally Car: 97 Honduh Civic |
Cosworth Paulinho Ferreira Super Moderator Location: Charlotte, NC Join Date: 03/15/2007 Age: Midlife Crisis Posts: 721 Rally Car: Honda Civic |
This is my car breaking an axle at a hairpin and look how far the Kaaz diff took me after that! |
It isn't that hard. Just make it the side and planet gears bigger, make the plates thick enough, make the case out on at least "cats steel" shot peen the hell out of it, or preferable steel. But. Problem is the horrible compromises designers have to do on LENGTHS of things when engines and gearboxes are placed in unnatural positions and in narrow spaces. A LOT of traverse boxes have difffs SMALLER than the little thing in my old ancient Saab--the diff was designed in about 1955. The halfshaft spline diameter was the same on my Saab --designed for maybe 38 hp as Dave Clarks gawddam 2.2 liter turbo GLH Doodge and the diff case was shorter, samller dia for the main part and the taper bearing seat was sunk or inset inwards on the one side--reducing interior space even more. Solution, buy a car that parts can be EASILY and AFFORDABLY upsized to something popular.... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
fidel lawrence knox Ultra Moderator Location: RVA richmond va Join Date: 03/11/2007 Age: Midlife Crisis Posts: 61 Rally Car: 78" volvo 242 |
http://www.drenth-gearboxes.com/products/differentials/honda-civic-type-r.html
if its in the budget lawrence knox aka fidel knox motorspors knoxmotorsports.us |
