MConte05 Matthew Conte Ultra Moderator Location: St. Louis, MO Join Date: 06/27/2011 Age: Settling Down Posts: 257 Rally Car: 1991 Subaru Legacy Turbozzzzzz |
Oh yes, his tire pressures were through the roof (32 cold). James, when did you drop the pressures down like I mentioned? Sounded like you went out on the first stage with the 32 cold? probably were low to mid 40's hot? I had mine at 19-20 psi hot. Probably could have dropped down a few more. |
What tires were you on? He was on D-mack and I'd guess the car is maybe 2650-2720 lbs so i suggested hot 23-24--(didn't ask what size derp derp) My favorite Michelins hot worked good at 23-24 but that was both a smaller tire (14-62 x 15) and a MUCH lighter 2020lb car. And driven what I would guess, much harder...(like top 7 o.a. Nationals) John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
BFGoodrich 185/something-15's. Medium compound. 3100lb car with both drivers in the car.
At 26-28 hot, they are skittish as hell. I've found that 18-20 hot is a great range with a lot of grip. But to be honest I haven't really experimented all that much. I also run an incredibly mild alignment. -1.5 camber in the front, -.5* in the rear, zero toe, no swaybars. Works out well, but again, haven't really experimented all that much. Might try a bit more agressive alignment with my new car. |
Nubby Tony Wells Mega Moderator Location: Omaha, NE Join Date: 07/08/2008 Age: Possibly Wise Posts: 191 Rally Car: SP Evo IX #112 |
What would people suggest for a 3300 lb car (yeah, we need to lose some weight off the car) and a 60F/40R static weight bias for hot pressure we should be shooting for? You can see our videos above, so "novice" driver. I'm getting a feeling our hot pressures are too high.
jbass James Bass Elite Moderator Location: Jefferson County, MO, USA Join Date: 11/01/2011 Age: Midlife Crisis Posts: 60 Rally Car: 2x 1985 Merkur XR4Ti |
Conte, we did heed your advice (thanks, by the way!!!), and I think the stage times show it - SS1/SS2 were pretty bad - until we dropped to uh- what- 22? 20? hot. I don't remember now - I need to play the audio track on the cam - I'm sure I was yammerin' it somewhere (really need to write this shit down!). But- after that it was much better. I'll admit, I was scared to drop it *too* much, because of debeading/etc. although later I found that's nothing to be worried about.
Yup -got some good advice (as always) from John V yesterday. Sometimes, it takes a bit to sink into my head, but hopefully it does, and hopefully we learn. I'd like to know more about relations on weight/tire pressure/size/pressure bias/drive type(rwd/fwd/awd) etc. too. We were running Dmack DMG2 175/75/R15 in G4. |
At hillclimbs (read: short stages less than 5 miles in length) with new BFGs I'd start with 22f and 20r. Our evo was probably 3350 with us in it back then. Now its ~3000 but some of that weight reduction was as the result of banning navvies. Dave |
Dante Allan Dantes Elite Moderator Location: Herman, MI Join Date: 01/27/2006 Age: Midlife Crisis Posts: 176 Rally Car: 87 Mazda LSRX-7 |
This makes me sad and optimistic.... as I have been running 28....cold..
I've hated not having traction.. Now I'm excited to test!! Owner, Driver, Head Mechanic, and Janitor at Tower City Race Team, headquartered near L'Anse. Michigan. Driver / CoDriver in Rally America, NASARallySport, ARA, AMS, UPMDA, Champ Off Road https://www.facebook.com/TowerCityRaceTeam/ https://www.instagram.com/towercityraceteam/ |
If it makes you all feel better, I first ran upper 20's as well, until I talked with Bill Caswell who told me to run low 20's, high teens, and that apparently Duplessis would drop it down to like 12-13psi if he was going maximum attack to get as much grip as possible.
