Off Topic
Pics from Placerville, Idaho
Posted by Gravity Fed
Re: Pics from Placerville, Idaho
December 26, 2012 08:47PM
100 guys with $230?
SeanP
Sean Lane
2000 Dodge Neon G2, bruised
December 27, 2012 04:07PM
It's Audi duty time!
you know how I know you are old?
shiza
Dan Norkus
94 Integra
December 27, 2012 08:14PM
Searching for cheap snow tires now! Also may need another set of wheels. My integra wants out of the garage!
December 29, 2012 11:40AM
Alex, there is a blue and white wire under the rear seat that is the speed signal wire for the rear diff. (goes into the diff controller) You can cut this wire and now the rear diff will not disengage automatically. You can also do some fiddling with resistors if you want to raise the cutoff from 15mph where it is stock, instead of disabling it completely.
Pete, S cars got locking diffs till 95.5 when they went with a brake control based traction system. Alex, pete is probrably right if the diff isn't working then you have a leak in the vacuum lines. I have extra.
December 29, 2012 12:49PM
ill check it out when I get over this cold.
