damn nice car.
Just like the Xratty, you have a basically excellent shell which is "furrin" but with a motor that is so common that most believe it is domestic.
The Ford V4 is just a shorter version of Ford 2600 V6, but most of the internals from the later 2,8 or even 2,9 V6 can be used with advantage....but every one of those V6s have been made on the same production line as when they started in Cologne back in 1961..
The Xratty 2,3 SOHC was made in Lima Ohio in 1973 then all the tooling was sent to Fords new plant in Tabaute, Brazil so since 1974 the 2300 was Brazillion made and they made a brazillion of them.
But try and tell that to the normal "consumeroid" and they'll get all "Buy 'merikun!" on you..
