I was gonna stay away from hydraulic and grab one of these.
http://yoshifab.com/store/index.php?_a=viewProd&productId=126 My only concern is if it will work with the pressure plate john supplied. |
Kyle Kyle Heacock Infallible Moderator Location: Portland, OR Join Date: 03/04/2013 Age: Midlife Crisis Posts: 21 Rally Car: 81 volvo 242 |
Now that the holidays are over, I finally found some time to work on the car again. I got the lower shock mounts relocated, so now there's some clearance between the coilover and the tire. I also found out the driver's turret is mounted farther outboard than the passenger side, so I offset the lower mount to keep the shocks parallel.
Going out of town for a week, so only keyboard building for a bit. I'm trying to figure out what to run for rear brakes. The front has stock gen 2 RX7 rotors and 4 pot calipers; in the rear, the axles have been machined to fit the same front rx7 rotors. I have a wilwood dual master pedal box with a 5.25 to 1 pedal ratio. I don't yet have any master cylinders (including the handbrake cylinder) or rear calipers.
Any suggestions on what would be a good rear caliper to match the front? And what master cylinder sizes to run? |
Volvo 240 rears... and those RX7 fronts are not going to work well without a booster... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I did some work on the Supra LSD, adding a Weir spring kit and shimming the side gears. It is getting set up now in the pickup 3rd member with a solid pinion spacer and 4.56 gears.
If anyone needs a supra diff housing, axle stubs, and/or a 3.90 final drive, let me know, because otherwise it's getting scrapped. |
I'll take it, I seem to have more than enough 4.3 sets...
Maybe set it side for when somebody is passing thru from there to here.. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Depends on what you're breaking. Good pressure plate can make some cars' forks and pivots break, or flex a lot. Reinforcing only does so much, a linkageless dealy is a great fix. If, as you point out, it's laid out so that it's not a major pain in the ass to service. Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
Just finished redoing the backstay V, since the old bars didn't leave enough room to fit the fuel cell without hulk-smashing it into place. I landed the new bars on the back stays instead of the turret support bars which gained a lot more room, and while I was in there I welded up a bunch of unused holes in the floor.
