Suspension travel
Posted by Pete
Suspension travel
October 07, 2014 05:01PM
I haz it.
Re: Suspension travel
October 07, 2014 05:03PM
Now that is a right proper race car!
October 07, 2014 06:15PM
Yah it's a lot of fun! That pic happened around the :45-47 mark or so:
There's maybe a half inch of travel left in the RF and the rear suspension has a ton more to go, you can jack a front tire six inches off the ground and both rears stay on the ground.
I'm freakin' loving the Black Rocket tires, too. Need more power to deal with all the grip they give.
Edited 1 time(s). Last edit at 10/07/2014 06:16PM by Pete.
RALLYRS
Mike Ball
Nope...I wish...RWD 2 Door Jeep XJ 4.0 5-spd Dirt-o-cross car(we have no grass!)2.3 ZX3 rallyx car(sold)
October 07, 2014 06:28PM
Ooh ...engine and suspension details please!
Support your Local North American Rally Forum!!
While they are still around-and get the hell off Farsebook!!
We still have Specialstage & RallyAnarchy.
Post up Here:
https://rallyanarchy.com/phorum/posting.php
and here:
https://www.specialstage.com/forums/forum.php
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
October 07, 2014 06:34PM
sounds great. smiling smiley
October 07, 2014 07:52PM
RALLYRS
I found the Group A 12A homologation paperwork which has port dimensions/diagrams, and so I copied the ports for my 13B but with bigger exhausts. That and the usual internal tweaks you do to keep it alive at high RPM, but really the engine is pretty tuckered out (it has 37,000mi on it) and I know the rear rotor housing is missing lots and lots of chrome. The suspension bas been detailed here before, but it's a 3 link and FC front suspension, with the shock mounts raised until the springs run out of travel/driveshaft bottoms out at full droop. Front struts are rear WRX and a lot of weldifying. 175lb springs everywhere, 14" front and 13" rear.
Really nothing complicated, very very basic and minimalist as far as prep goes. This winter I hope to score enough cheap used stuff on eBay and craigslist to put an aluminum cased full floater 9" rear in it, but I'll keep the current geometry because it just works.
Edited 2 time(s). Last edit at 10/07/2014 07:58PM by Pete.
October 07, 2014 08:37PM
::a challenger approaches::
Mulvey14
Liam Mulvey
84 Mazda rx7
October 09, 2014 07:58PM
Looks like a nice setup. Are rear shocks and springs in the stock location or are you running coil overs
Liam Mulvey
October 10, 2014 05:02PM
I moved the shock mounts up an inch on the rearend because the shocks were topping out before the springs and driveshaft. That's it.
The springs are for, i think, a mid 90s Escort wagon. $80 MOOG bits from NAPA.
mellow65
Oliver Klozoff
Nada
October 11, 2014 02:43PM
I was going to do this but with the STI struts that I had, there was a crap ton of travel in those things.
Any pics of the three link inside and out? it on my list of things to try someday.
October 11, 2014 02:48PM
mellow65
wot dafuq?
All the Subie fronts I have seen are 160mm travel---not a crap ton of travel in my book....190 is good, 210 is better.
mellow65
Oliver Klozoff
Nada
October 11, 2014 02:53PM
mellow65
Front struts are thumbs upREARthumbs up WRX and a lot of weldifying.
wot dafuq?
October 11, 2014 03:01PM
mellow65
mellow65
wot dafuq?
Oh so 210 then.. (I see cross-eyed at close range) You give any thought to their valving is for a realtively light end of the car so a light spring?
mellow65
Oliver Klozoff
Nada
October 11, 2014 03:09PM
mellow65
mellow65
wot dafuq?
I like the valving on the front STI ones i have on there right now, it's pretty fun off road. I'm sure the rears are different but who knows. No real money will ever be thrown at my car.
October 11, 2014 03:12PM
Well, they are adjustables, and I knew they wouldn't be "ideal" but, well, the parts were there and the welder was there and even if you fall on your face you have still moved forward... (It was $60 for a pair of Koni Yellows for a '02-03 WRX. Bought them for a quick flip, turns out nobody wants Konis because you have to *GASP* cut the tops of the strut housings off!)
They work fine except they have a tiny bit too much initial damping, they're a bit stiff over light bumps. Certainly a hell of a lot better than the worn out KYBs I had before. Stock WRX/STI rear spring rates are higher than the 175lb-in i am running (225, I think?) so I didn't think that'd be an issue.
Edited 2 time(s). Last edit at 10/11/2014 03:19PM by Pete.
