What did I do On Kevin's, Houston's, Ian, and Alexs' rally Volvo 240s today?
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
Re: What did I do On Kevin's, Houston's, Ian, and Alexs' rally Volvo 240s today?
February 20, 2008 01:07PM
So how does Tim's design avoid binding condition that would occur with reinforcing the stock trailing arms?
February 20, 2008 01:53PM
> trailing arms?
This is a cheaper to make version that John suggested. A bit closer to a real solution. All the yellow bits are spherical bearings. The two at the back create an axis of rotation thru the centerline of the balls shown by the red arrow. This decouples the bending moment from the toe link that flexes the stock trailing arm. So no binding but they can still transmit inline forces and brake torque.
Andrew_Frick
Andrew Frick
February 20, 2008 02:42PM
Alright I am on board now. Thanks for the explanation.
February 20, 2008 08:27PM
here ya go original source of ideeeer
eyesoreracing
Dave Coleman
Mazda3, SE-R Spec-V, 510
February 20, 2008 09:54PM
It always comes back to Ford Rallye somehow.
So what car was that piece for, and what type of suspension was it?
-Dave
February 20, 2008 10:23PM
Ford RS2000, probably stock shit looked just like yours.
FWD Formula 2 car.
February 20, 2008 11:48PM
> yours.
> FWD Formula 2 car.
Damn Grant, don't you ever bother to look at those fuckin books?
(I guess not otherwise you would have figured out how to mount the sumpguard mounts and the crossmember /support.)
The part is the toe control link from 1990 Ford Sierra Sapphire 4x4 GpA
View pulled back gives a better idea:
This is the RS2000 rear stuff:
> Grant Hughes
> Denver, CO
