Re: Rear Shock Turrets For Volvos
January 12, 2008 11:43AM
Adam is probably solid works. I'm not sure about Tim. When I attempt this stuff, I use rhino3d, haha.
January 12, 2008 02:25PM
hudson Wrote:
> what program are you guys using? Autocad?? If so
> damn
> Cheers
> Andrew McNally
> Hamilton ON
> 28
I'm using SolidWorks 2007 at the moment.
Tim
January 12, 2008 03:48PM
> damn
> Cheers
> Andrew McNally
> Hamilton ON
> 28
Man what I'd give to be able to design shit like this. I hope that you love your job Tim. I'm jelous. What's the issue on the rear of Volvo's that there isn't a proper upside down thing residing in there?
January 12, 2008 05:22PM
david amor Wrote:
> If so
> > damn
> > Cheers
> > Andrew McNally
> > Hamilton ON
> > 28
> this.
Don't worry, I tell him every time we talk "Damn you!!!! It's not fair!!"
> residing in there?
Some cars use things called "shocks" and Toilettas, and old Fords, Xratties and VW and Volvos use these old things:
That's one of the 50mm (same internals as your Soooper Bitchin JVAB struts) magnesium bodied shocks I bought used from Stig Blomqvist in Sweden.
The steel ones work the same just weight a pound more.
Edited 1 time(s). Last edit at 01/12/2008 05:22PM by john vanlandingham.
January 12, 2008 10:37PM
acrane Wrote:
> red .75"OD .5"ID busing slides to pinch shock.
So Adam, I've always been wanting to try that sliding pinch bushing trick since I first saw it on a Swift FF about 10 years ago. How critical was the fit on the bushing to keep things tight and not knocking about smushing the hole oval?
Tim
January 13, 2008 12:16AM
Tim Taylor Wrote:
> shock.
> Tim
What are you seeing? What's the point?
January 13, 2008 11:30AM
> Tim Taylor Wrote:
> > shock.
> that
> it
> critical
> tight
> oval?
> > Tim
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.jvab.f4.ca
On Adam's model there is a section of box tubing on top of the turret. It has two pieces of 0.75" OD x 0.50" ID tubing running across it where the bolt mounts. One side is welded solid on the outside and the other slides thru a (my question: precision bore or just drilled hole).
It's usually done that way on lightweight formula cars to protect the casting on a transaxle where a rod end bearing mounts. The sliding section of tubing keeps hack mechanics from over tightening the bolt and breaking the ears off. As a bonus it's cheaper to make because you don't have to hold a tight tolerance on the slot.
January 13, 2008 11:40AM
Maybe it's that lack of imagination/creativity I was saying I suffer from, but
"what da fawk?" Sounds like an excellent opportunity for having a bunch of slop develop over time and the vital red spacer to disappear in a hurried (or ya think of it, more lkely a lazy in garage ) shock swap.
Still don't understand what is the point in this application.
Never saw any particular shortcomings with the Xratty top mount.
Hold the shock up, slide a bolt thru.
Seems easy 'nuf.
January 13, 2008 11:49AM
Calm John, breath deep, now exhale... I wasn't planning on using it. I was just curious how it worked for him.
January 13, 2008 12:07PM
> worked for him.
I know you wuzzzn't gonna, I am just curious what proble this supposed solves cause I dun understand nuthing, I knopw Adam is an astute fellow, and I learn by unnerstandk howz other guys think they're solving problems.
Or......... is like when the US Army guy back at the old Checkpoint Charlie an der grenze im Berlin shouts to Ivan just accross the line and says "Ivan, run for it! Come on over! We'll cover you!"
And Ivan shouts back "Why I come over there? We have best system in Sovjet, better than Consumer Capitalist Wage slave live you live! HA!"
The US Army boy is dumfounded and shouts back "Better sysytem?? Are you crazy? How is Soviet system better, We have everthing here!??"
Ivan shouts dripping with contempt "Sovjet system much better! We solve problems you don't even have in the West!!"
January 13, 2008 03:06PM
> > worked for him.
> solving problems.
I don't know why Adam used that design in his application. Maybe he just wanted to play with it and see how it worked...I do that sort of thing all the time. Not everything Ford did back in the day is the end all and be all of designing race cars :-) It is a particularly elegant solution for preventing damage to cast mounting ears. I have a better drawing of what we're talking about below.
The suitability or necessity of the sliding bushing on a ductile mild steel mount is not what I'm asking about. I just want to know what kind of tolerance he has on the bushing fit and while we're at it what's the wall thickness of the box tube?
FIXED EARS:
SLIDING BUSHING EARS:
acrane
adam crane
corolla GT-yes
January 14, 2008 12:53PM
SW2008,
Looking for a job near / in Redmond after DooWops.
It is working fine, way better than for the first 3 years of prepping/rallying where the shock eyes were free to bounce forward and aft inside that housing as they pleased, creating some nice clanks at full droop.
the reason i'm not going for Johns pressed in superfly reducers is,
shocks ship with 1/2" eyes, from bilstien. the rest of the car's 4-link is also 1\2-20.
i never managed to ovalize the 1/2 drill hole, so i'm even less concerned about it now with a much larger bearing surface.
i actually used a drill bit (3/4"winking smiley, and doubled it with some left over tube, tweaked in the lathe. the clearance isn't critical, and as a bonus, was tightened when the blue extra guide was welded to the main piece. you would have to try really hard to loose it. (blast it out of the car)
I have occasional access to a lathe, not enough to do up 20+ reducers, but enough to part a couple non critical lengths of tube.
i have run my shocks upside down, and the bearing height is much closer than you show, that's why there is an enlarged hole and gap cut out of the square channel.
"I put the hurt on dirt" - adam crane
http://CraneRallyCrew.com
corolla gt-s "Patches"
Op: S.S.
open | download - turret4.jpg (43.5 KB)
January 16, 2008 06:07PM
hey you guys
i am not flaking out, Im really sick 104 fever cant walk or talk. Tim I ll get the car to you someday soon
I found some good looking turrets from the old country
check out lighspeedmotorsports.se
the blue 240
thanks -Al
January 16, 2008 07:16PM
alkun Wrote:
> hey you guys
> someday soon
Dayum Man, is it the plague?
> country
> the blue 240
Yeah they're a favorite
> thanks -Al
