Mark 4 VW 1.8T GTi Build - RallyCross - MF Class
Posted by DanielSL
Re: Mark 4 VW 1.8T GTi Build - RallyCross - MF Class
July 14, 2016 11:45AM
Paddy1337
Of course, I don't know nothin', I've only been doing it since back when there were four classes and it was scored autocross-style, only fastest single run counts.
Wait. Have they gone full autox style with classing now? Last time I did an autox there were 4 classes; 2wd & 4wd, each of which broken up by street tire or rally tire.
In 2004 it was run watcha brung, under or over 2 liters divided by two or four wheel drive. Then they did a bunch of things and now it's settled on a matrix of stock/prepared/modified and front/rear/all wheel drive.
Funnily enough, modified rear and front were one class until 2012. Everyone ran a front drive car except for one or two people here and there. Now MR tends to be the largest class always (have been to where they outnumbered all AWDs combined) and MF is shrinking drastically.
At Eastern States there were 14 MR cars and four MF.
July 14, 2016 08:23PM
I have never seen a thoroughly gutted car run faster than a heavy car.
With the exception of a 2.slow A3 golf or A2 of any ilk.
July 14, 2016 08:30PM
And you know what THOSE have that most other cars don't have?
The absolute minimum of unsprung weight. The twist beam rear suspension basically has none, the front end is very minimalistic, and heck a lot of those ABA engined cars still had solid 9.4 rotors up front.
Leon Drake's Rabbit/Golf/Caddy thingus is kind of an exception with its Miata rear suspension, but he has the suspension nailed, and that car is planted, looks like he can put the car anywhere he wants to. It doesn't bounce all over the place like most super lightweight cars do. THAT is the key thing, if the car isn't stable then you can't put it where you want to and, in this discipline, that is the #1 criteria over all other things.
Edited 1 time(s). Last edit at 07/14/2016 08:34PM by Pete.
tdrrally
edward mucklow
July 15, 2016 08:22AM
so what is being said is , the best investment is seat time?
July 15, 2016 12:59PM
Practice with many entry of event. Not dumb shit stuck on side of car.
DanielSL
Daniel
2005 VW Mk. 4 Golf GTI 1.8T
July 15, 2016 04:16PM
Pete; Leon Drakes build of his Caddy was the reason I decided to get back into motorsports again. I saw his build on Vortex, researched RX, and saw my Region did all their events close to my home, and went from there. His pictures of what his golf looked like after its roll is the reason I went with the decision of a full cage instead of a bar, after promising my wife I would take no more risks after the motorcycle accident.
Edward; Any thing you do needs "seat" time to get better. Thats kind of an understatement, and pretty much rhetorical. Autocross, RX, track attacks, defensive driving, boating, offshore racing, flying planes or helicopters. It even crosses over to sports. Practice makes perfect. I don't care if it was playing the drums when I was a kid, or live fire practice when I was in the military. But you cannot have seat time in a car, without a running car first, lol.
July 15, 2016 04:40PM
I was there for one of his rolls... which happened after a rear stub broke... Keeps giving me pause regarding rallycrossing my GTI.
Of course I have an interesting solution sitting on the floor at the shop...
danster
Haggis Muncher
VWs (for my sins)
July 15, 2016 04:41PM
tdrrally
Quite possibly, but as long as that "seat time" is actually spent driving the car and not sitting on a seat in front of a computer fapping on t'internet about driving the car.
DanielSL
Daniel
July 15, 2016 04:52PM
That's the one. And from everything I researched, going to Mk. 4 stub axles was the answer... hence why I chose a Mk. 4 for my starting point. With the loose and lax RX rules, I could have put a built 2.0 16v, or a 1.8T into a Mk.1 or Mk.2 if I wanted to, but parts support and ease of finding a rust free shell on a Mk. 4 just made good sense.
I even ended up going with Kirk for my rollcage builder, because of Leons thread.
DanielSL
Daniel
July 15, 2016 06:07PM
Here's where I am sitting at ride height wise, for now. Obviously, with the new engine/trans installed, and the weight of the cage being pretty much equalized in the center of the wheel base, I am expecting it to settle about a 1/2 inch to an inch in the rear, and almost two inches in the front.
The roller wheels are full sized spares, and they are 185/70 tires, so this should be about what it looks like with the DMacks mounted.I have to finish modifying the stock GTi front bumper cover to fit the larger front mount intercooler, and remove the splitter, as that will only lose me clearance.
Edited 1 time(s). Last edit at 07/15/2016 06:13PM by DanielSL.
open | download - GEDC0212.JPG (62.2 KB)
DanielSL
Daniel
July 20, 2016 02:02PM
Rear suspension question:
Instead of spending the money on the Bilstein HD's, and then after only a season or so, replacing them; I am thinking of just biting the bullet and going with the HotBits suspension. Its expensive, but at least its in my budget.
With the rears, the OE travel is 235mm, which is 9 1/4". HotBits shortens the travel to 219mm, or 8.6". Does this make sense to those of you that have run solid rear beam VW's in competition. Will this be enough travel? I know I'm building for RX, but if I do decide to run a couple of Rally Sprints per year, I want to be able to do it on the same suspension at this price point.
Thanks.
tdrrally
edward mucklow
July 20, 2016 02:15PM
DanielSL
Thanks.
i would spend the money with john, better than hotbits and still have all the travel!
July 20, 2016 02:31PM
tdrrally
DanielSL
Thanks.
Thank you and yeah even the inverted 40s are HUGELY better suited than those horrible nearly ridgid, oversprung, short travel Hotbitch thangs..but still way OVERKILL.
But I have spoken with this guy, he does not listen, and he "wants to" spend money...I said for what he is doing new-ish fresh stock stuff WILL WORK and BE BETTER, and that my stuff costs well over what he decided in advance what he "wants to' budget..
All very backwards thinking : I hain't never done this but I'm making BIG PLANS and I haz a BUDGET for what I want to spend (which has no relationship to anything)"
The Hotbitch would be a complete waste of money..
Therefore this guy will PROBABLY do it.
Thomas Kimsey
Thomas Kimsey
1988 XRatty
July 20, 2016 02:42PM
A car just competed NEFR on off the shelf Bilstein HDs with two rallysprints and two rallycrosses on them and the suspension is still fine.
DexterVW
David Baker
95 GTI TDI
July 20, 2016 02:52PM
Thomas Kimsey
Even with a crash that tore the trans mounts off and almost burning up on the trailer.
