89 Volvo 244TIC Street car
Posted by TerribleOne
Re: 89 Volvo 244TIC Street car
June 27, 2008 09:08PM
yeah, and you are going to empty your welding tanks trying to get that thing hot eonough to braze.
The way to repair that would be to heat the whole thing then weld it with the special rod, but it would never be the same and probably crack elsewhere. You might be able to find a specialist who can fix cast iron, but it wont be cheap.
It doesn't really relate, but back in the good old days we used to fix the melted exhaust ports in our 2 stroke motorbikes with JB epoxy weld! It worked great.
TerribleOne
Vince McAllister
89 Volvo 244tic
July 07, 2008 10:10AM
It's okay, I'm selling the car.. I needs a work truck more than I need a playtoy.
It's up in the for sale forum..
Stroker 2.5 redblock, JE forged blower pistons 8.2:1, Eagle H beams with DSM big end, Avalanche underdrive pulley, 46/40mm valve 530 with Enem C2 turbo cam, Isky db springs, SDS efi w/DIS/wasted spark, PCS digital touch screen dash/logger, 60lb Deka IV's, ATP 60-1 @ 22psi, Tial bov, Walbro 255, Avalanche T-5 adapter, 02 Tremec 5sp, 6puck, 3" driveshaft, modded G80, Painless chassis harness. Corbeau seats.. 300+whp Driven daily..
Haztoys
David Rodgers
90 Mitsu truck ..And needing something new just not sure what..???
July 07, 2008 10:30AM
> braze.
> worked great.
I weld cast all the time ... The hard part is finding the right rod to weld it with...I have a note book I write down what rod I welded what with ... Do some digging theres a welder some were around you who welds cast ... I have a rep for welding cast so cast finds me ... Did you have a brace on the turbo..??
TerribleOne
Vince McAllister
89 Volvo 244tic
July 14, 2008 11:54AM
Well.. not only did one side break the other side of the flange broke as well.. I dont have a brace on the turbo, but I do have one on the bottom of the manifold and my exhaust has a 10" stainless flex section in the vertical position on the downpipe..
TerribleOne
Vince McAllister
89 Volvo 244tic
September 30, 2008 05:33PM
Ordered a new turbo finally.. It's a 60-1 (T04S) with a journal bearing cartridge and stage three wheel in a .82 5 bolt housing.. Should be fun once I get all of it together.
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=77747922&albumID=2047716&imageID=35235742
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=77747922&albumID=2047716&imageID=35236000
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=77747922&albumID=2047716&imageID=35236338
open | download - DSCF0944.jpg (111.9 KB)
