I'm unclear about how this nut AynRand has to do with what looks to be a promising limited slip device for our Volvo rear....
Sooooo what would need to be done with axles to make it work? Is this an opportunity to have stronger axles made? I have broken more Volvo axles in the splines at the carrier then I care to count. I would welcome the opportunity to reduce unsprung weight by swapping a Volvo axle back into the car that would take the power my turbo six makes. Even with the Aluminum center section the 9" thing with the 35 spline axles is very heavy. JohnLane Overkill is consistently more fun |
TerribleOne Vince McAllister Super Moderator Location: Mangohick Va. Join Date: 08/11/2007 Age: Midlife Crisis Posts: 71 Rally Car: 89 Volvo 244tic |
Nobody want's to hear about your heavy 35 spline 9" thing..
Stroker 2.5 redblock, JE forged blower pistons 8.2:1, Eagle H beams with DSM big end, Avalanche underdrive pulley, 46/40mm valve 530 with Enem C2 turbo cam, Isky db springs, SDS efi w/DIS/wasted spark, PCS digital touch screen dash/logger, 60lb Deka IV's, ATP 60-1 @ 22psi, Tial bov, Walbro 255, Avalanche T-5 adapter, 02 Tremec 5sp, 6puck, 3" driveshaft, modded G80, Painless chassis harness. Corbeau seats.. 300+whp Driven daily.. |
fiasco Andrew Steere Mod Moderator Location: South Central Nude Hamster Join Date: 12/29/2005 Age: Possibly Wise Posts: 2,008 Rally Car: too rich for my blood, share a LeMons car |
Tim Taylor Tim Taylor Super Moderator Location: Oakland, CA Join Date: 02/02/2007 Age: Possibly Wise Posts: 622 Rally Car: Mazda 323 GTX |
JohnLane Wrote:
------------------------------------------------------- > Sooooo what would need to be done with axles to > make it work? It bolts into a stock Volvo housing so the only real modification is to re-spline one of the stock axles shorter and get another one made longer. Al wants to go cheap so we're going to have Moser do the cheapie respline on axles we supply. > > Is this an opportunity to have stronger axles > made? > > I have broken more Volvo axles in the splines at > the carrier then I care to count. Yup, Moser will make a set of new alloy axles for $315 per pair. Or you can have Mark Williams make you a set of gun-drilled 4340 ones Mr. Overkill. > > I would welcome the opportunity to reduce unsprung > weight by swapping a Volvo axle back into the car > that would take the power my turbo six makes. > > Even with the Aluminum center section the 9" thing > with the 35 spline axles is very heavy. > > JohnLane > > Overkill is consistently more fun You can check the axle shaft sizing on their slick little calculator: http://www.moserengineering.com/Pages/axletech.html And because you might need it: REPLACEMENT POLICY Moser Engineering, Inc. will, at its’ sole discretion replace or repair, free of cost, any part found not to be of ordered dimensional specifications, prior to assembly or use of the part. In addition, Moser Engineering, Inc. will replace their 33, 35, & 40 spline axles for a period of ten (10) years after the original date of purchase if broken at the splined end due to excessive horsepower. However, 33 spline axles that were broken due to excessive horsepower will be replaced at the sole option of Moser Engineering, Inc., with 35 spline axles. In the event that 35 spline axles are broken due to excessive horsepower within ten (10) years of purchase, they will be replaced at the sole option of Moser Engineering, Inc., with 40 spline axles. If 40 spline axles are broken due to excessive horsepower, they will be replaced at the sole option of Moser Engineering, Inc with another set of 40 spline axles, free of charge. Edited 1 time(s). Last edit at 03/16/2008 11:11AM by Tim Taylor. |
JohnLane Wrote:
------------------------------------------------------- > I am tempted to have a set of axles made up and > give them a whirl with a welded up open carrier. I can get another hydra-lok for $200. Plus they're not violent on axles like a spool, welded carrier, or detroit locker. I saw some video of the pavement stages doo wops and your car would defiantly turn in a smoother with a hydra-lok ![]() > > > Hmmmmmm...... > > The 9" thing is all new in the center section, > which is a disincentive to make a change. > > > > JohnLane > > Overkill is consistently more fun I'll bet there is more weight that could be taken of your 9". Is the ring gear turned down, gun drilled axles, thin wall chromoly tubes with good bracing, trac9 lightweight housing? I'll bet the weights could be made comparable. Tim |
Tim I may well do such things in the future.
Certainly gun-drilling the axles would be a nice thing. I'm curious as to how the Hydra-Lock diff would handle. Something I do like about a spool or welded diff is that it is very consistent. JohnLane Overkill is consistently more fun |
acrane adam crane Senior Moderator Location: Seattle, WA Join Date: 01/28/2006 Posts: 382 Rally Car: corolla GT-yes |
our friend up here RAINBOW LARRY google: rainbow auto service
has all the stock axles i'll ever need for the back of my corolla. and all the 240 shells john could want, and even two merkurs. (4 if you count the sierras) having a limited slip in the corolla was nice, very. john L. is right about the spool thing. but i'm interested in the hydra-lock. i've got five on it. 700 max to bolt into a dana30 rear with the 5.3gear on it. and you say $350 for my pair of spare axles? he sold me an entire rear end for $150. "I put the hurt on dirt" - adam crane http://CraneRallyCrew.com corolla gt-s "Patches" Op: S.S. |
acrane Wrote:
------------------------------------------------------- > our friend up here RAINBOW LARRY google: rainbow > auto service > has all the stock axles i'll ever need for the > back of my corolla. > and all the 240 shells john could want, > and even two merkurs. (4 if you count the > sierras) > > having a limited slip in the corolla was nice, > very. > john L. is right about the spool thing. > but i'm interested in the hydra-lock. i've got > five on it. 700 max to bolt into a dana30 rear > with the 5.3gear on it. and you say $350 for my > pair of spare axles? > > he sold me an entire rear end for $150. > > > "I put the hurt on dirt" > ex. madmann28 > adam crane > bellingham wa > corolla gts > bs. from VRI @ WWU Hey Adam, The $350 is for a pair of new Moser "alloy" axles. We're just going to have them re-spline some stock ones. Last time I checked they will re-spline an axle for $40 each. So $20(junkyard 744 axle)+$80(re-spline)+$200(hydra-lok)=$300 which is still way less than just buying a new Dana 30 power-lock which will split a cross shaft. Tim |
i bet they would make them up so i could run my 14" toyota wheels too! 4x113? hub-centric?
Sign me up. ( do all the work for me! ) "I put the hurt on dirt" - adam crane http://CraneRallyCrew.com corolla gt-s "Patches" Op: S.S. |
acrane Wrote:
------------------------------------------------------- > i bet they would make them up so i could run my > 14" toyota wheels too! 4x113? hub-centric? jeeeeesuz its 4 1/2" silly boy > > Sign me up. ( do all the work for me! ) > > > > "I put the hurt on dirt" > ex. madmann28 > adam crane > bellingham wa > corolla gts > bs. from VRI @ WWU John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
MrToad Jim Turner Mod Moderator Location: Maine Join Date: 12/11/2007 Age: Fossilized Posts: 36 Rally Car: none, gopher |
