sagsert Mustafa Samli Infallible Moderator Location: Arizona Join Date: 01/10/2006 Age: Ancient Posts: 824 Rally Car: Gaylant VR4 |
derek Derek Bottles Ultra Moderator Location: Lopez Island/ Seattle WA Join Date: 12/20/2005 Age: Possibly Wise Posts: 853 Rally Car: Past: 323, RX2, GTI. Next up M3 ? |
This site started because I like what Sailing Anarchy has done in the sailing world so I pointed out how we could do the same in rally. It is a direct copy of Scott Tempersta's vision and efforts.
Jens sometimes you have good ideas and sometimes you do not, just like everyone else. I rather like your posts and think it is funny how everyone feels they need to respond to them because they are so hurt by what you say. I think it is better to let them stand by them selves where they can show you be the ecentric that you appear to be. So as far as I am concerned pls keep posting. When I do not like what you write, I can easily skip a post. Derek In the long run reality always wins. |
Morten Morten Ultra Moderator Location: Vancouver, BC Join Date: 01/11/2006 Age: Ancient Posts: 366 Rally Car: 1974 Dodge Colt |
I agree with you Derek, I too will skip a post I disagree with. (at least I'll try to)
I enjoy this site, and appreciate it's helpful nature. It seems like a real community, possibly the way Rally used to me ? I did receive a recent PM from Jens that I appreciated. Just goes to show you that eventhough stereotypes abound, just a little effort goes a long way. |
Scott Manley Scott Manley Ultra Moderator Location: Spokompton, WA Join Date: 01/03/2006 Age: Possibly Wise Posts: 226 Rally Car: XR4Ti |
Darn this really was a good topic at the start.
Skye- I can't see why an electric oil gauge wouldn't work. As long as the threads for the sensor or capulary tube match the port on the rail. Or just mount a gauge on the rail and an idiot light on the dash for low pressure. Scott Manley Spokane, WA 86' XR4Ti 37 |
Well the interesting thing is in looking inside works cars was as sparse as instruments were, right there was a fuel pressure guage. Thewy leave out a lot of things but included that.
I think I might put the sender back by the pumps and the "Inspection port". But remember Ford is running really high boost (2 bar boost, 3 bar total) and it really wants fuel exactly right. You 2wd guys are running stock motors, maybe the T-bird vam when we get the plumbing right. I think its a little less critical to have a permanent mounted sender and guage. Set it up with the junk taped on and the Wide band meter taped on and pull it off. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
nick the brit Nick Taylor Godlike Moderator Location: North Hollywood, CA Join Date: 01/25/2006 Age: Possibly Wise Posts: 149 Rally Car: 1995 Subaru Impreza WRX |
------------------------------------------------------- > Well the interesting thing is in looking inside > works cars was as sparse as instruments were, > right there was a fuel pressure guage. Thewy leave > out a lot of things but included that. Now that's interesting to me. I had originally bought just about every gauge available to mount in the Subaru (I fabbed up a 6 gauge pod for the dash), then chatting with Steve Mcnaughton (Ralph K's crew chief) he just about laughed! What should I be looking at mounting in the car? I have a fuel pressure gauge, voltmeter, Exhaust gas temp gauge, boost gauge, oil temp, water temp available to use. I know the modern cars have the fancy Pectel style Cray supercomputer digital dashboard displays that tell you what time to get up and when your Roast Beef is done - but I don't need to play Playstation while driving! Nick Taylor. Knobhead. Los Angeles, CA. |
Skye Skye Nott Professional Moderator Location: Vancouveh Join Date: 12/18/2005 Age: Possibly Wise Posts: 476 Rally Car: Xratty |
Good, except why EGT ?
As far as water temp, the stock cold/warm/hot is good enough IMO, don't need to know exact temps. www.rallyrace.net |
In my first rally car I had gadges. Turned out I like to look at them from time to time. That was slow. Esp. when I looked and saw something not so good like is the turbo making boost, or is the temp high...
Now I have a low oil pressure light - that is it. I am much faster. It is not like I am going to stop anyway till the car will go no farther. Jens is right we now run sprint events. There is no time to spend trying to trouble shoot, it works or it dont. If you pull over you lost the rally so do not pull over. I mean what will you do with low fuel pressure reading? If the car runs keep going if not stop. Do you carry a spare pump, Filter etc? I have a gadge in the service van so if we make it back there we can test. Same for voltage meeter, and temp things. Derek In the long run reality always wins. |
derek Wrote:
------------------------------------------------------- > > I mean what will you do with low fuel pressure > reading? Know what your problem is. If the car runs keep going if not stop. > Do you carry a spare pump, Filter etc? Yeah, Skye listens and has _2_ pumps plumbed and wired > > I have a gadge in the service van so if we make it > back there we can test. Same for voltage meeter, > and temp things. He has a switch on the dash panel. Flip switch, run pump 2. > > Derek > > > > > > See me go at: > www.11tenths.com > In the long run Reality always wins. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Yup, I just copied Ford Motorsport.
I'd rather DNF with broken alternator, water pump, etc than DNF with blown engine. Pulling over is pulling over, the difference is how much $$ it will take to get it running again. ![]() www.rallyrace.net |
So you really going to look at that gadge and say look it is low flip the switch?
That is slow, if the car misses you will say hmm try the other pump, that is not so slow and do not require gadge. Ever so slightly lean is a problem, big time lean is not a problem because there is not energy to make too much heat. IF you must have a gadge get egt or mixture. Fuel pressure no tell you anything. The recording EGT is good so you can see max heat on a stage. But again I would bet if pressure goes down a little then the ECU will go, look too lean at the OX senssore and hold open the injector longer. How else would the ecu deal with dif mix of fuel with difrent specific gravity and dif temp of the fuel etc? All fuel pressure will do is scare you and slow you down. D In the long run reality always wins. |
I'm just copying Ford Motorsport. They must have done it for a reason. The Sapphire was done the same way.
www.rallyrace.net |
Parry Dave Maxwell Infallible Moderator Location: secoast NH Join Date: 02/17/2006 Age: Midlife Crisis Posts: 97 |
Get EGT.
Preferably a digital one. If you want to have a fuel pressure gauge too, that's fine just put it under the hood. You have NO TIME to look at it when you are in a stage. Cheers M.Samli Phoenix AZ Gaylant VR4 EVO III GSR (Stolen) Rallies are no place for traitors |
I wasn't planning on looking at it on a stage, only if the engine is misbehaving. I have a superbright red LED idiot light for oil pressure, that's the only thing I'll notice. I'll look into EGT. Would like to do a temporary wideband O2 for tuning at some point.
www.rallyrace.net |
