Stitch welding.....all or nothing?
April 23, 2008 07:23PM
So, I've seen how the VT Sport car guys do it.....not gonna happen.
Is it worth it to do 'half' (or a third?) of the car? Interior, trunk, wheel wells/quarter panels, engine bay (if I decide to drop the engine)....
Basically the stuff you can easily reach, and not the stuff you can't.
Is this worth the effort as a DIY project or no?
Edited 1 time(s). Last edit at 04/23/2008 10:43PM by Jon Burke.
hudson
Andrew McNally
Re: Seam welding.....all or nothing?
April 23, 2008 08:53PM
I'd say some of the most important stuff is in the engine bay.
Andrew M
Onterrible
30ish
April 23, 2008 09:24PM
Another way to "stitch weld", you're probably already aware of, is Structual panel adhesive urethane. In tests it's been proven to be as strong as a weld. Ok, hard for me to believe it's as strong as a weld, but probably almost as strong.
It might be an easier way out for you in the areas you don't want to weld.
http://www.autobodysupply.net/category-s/79.htm
Duramix 4176 4178 4179
These 3 are probably your best best if you're working with steel. The larger the panel the longer the cure time an working time. You'd have to talk to someone more knowledgeable than me to find for sure which is the strongest.
They also make foams which could be used in your A, B, C, pillars and in the rockers and frame rails.
Duramix 4350 and 4330 are you best bets there.
Anyhow... I grew up in a high-end bodyshop and we used those products and had great results and long lasting repairs. I agree with Andrew and that the areas that really matter are in the engine bay, and any joints such as pillar areas, rockers, frame rails areas and suspension pickup points.
But I'd totally be open to hear more from people with real-world-rally experience, but that's my 2 cents.
-Michael
Re: Stitch welding.....all or nothing?
April 23, 2008 10:59PM
oh yeah...stitch! that's what I meant.
"Another way to "stitch weld", you're probably already aware of, is Structual panel adhesive urethane. In tests it's been proven to be as strong as a weld. Ok, hard for me to believe it's as strong as a weld, but probably almost as strong.
It might be an easier way out for you in the areas you don't want to weld. "
actually, I wasn't aware, so thanks for that....something to research.
April 24, 2008 03:15AM
VT and other US 'rally' prep shops don't actually 'stitch' or seam weld to even the level that mid 80s rally cars were. They just rely do enough and rely on rich customers. At least that's been my observation.
April 24, 2008 12:04PM
But then again, these cars arent put through the paces like... ya know!
April 24, 2008 12:49PM
> observation.
> Grant Hughes
> Denver, CO
gotchya, my comment was just going by this...
http://rally.subaru.com/rallyprep.html
April 24, 2008 01:04PM
My opinion on seam welding is to seam weld anything that I can easily get to on this shell. My next shell, which I will start prepping once I get one, I will strip it down to the shell and remove all the glue and seam weld after the cage goes in. But on the first shell, which I am treating as fairly disposable, I only seam welded the seams inside the car.
April 24, 2008 01:32PM
These aren't rally cars but this applies to all unibody cars. This is an excellent build from a fabricator in Japan who owns Opera Performance. Very Impressive. Notice the areas where he "lapps" panels to increase strength of the unibody. These are the critical areas. The articles are ok but the "related photo" gallery speaks volumes.
S2000
http://www.sportcompactcarweb.com/features/0611sscp_opera_performance_honda_s2000/index.html
350Z
http://www.sportcompactcarweb.com/features/0611sccp_opera_performance_nissan_350z/index.html
RSX
http://www.sportcompactcarweb.com/features/0611sccp_opera_performance_honda_rsx/index.html
Edited 1 time(s). Last edit at 04/24/2008 07:06PM by pikespeakgtx.
April 24, 2008 02:51PM
pikespeakgtx Wrote:
> Not rally cars but all unibody cars share the same
> weaknesses. This is an excellent build from a
> S2000
Don't understand what you mean by "lapps".
Cut and paste a photo or two to illustrate.
> 350Z
> RSX
April 24, 2008 03:31PM
By Lapping I mean welding oem panels over high stress areas in order to increase the overall strength by doubling up the material.
open | download - 0608sccp_08z+honda_integra_type_r_dc5+body_left_side.jpg (40.3 KB)
open | download - 0608sccp_09z+honda_integra_type_r_dc5+door_frame.jpg (38.1 KB)
open | download - 0608sccp_10z+honda_integra_type_r_dc5+body_right_side.jpg (49.5 KB)
April 24, 2008 03:32PM
a couple more high stress areas in the b and c pillar areas
And he's doubled the thickness of the oem floor pan in the rear hatch area.
Edited 1 time(s). Last edit at 04/24/2008 03:33PM by pikespeakgtx.
open | download - 0608sccp_20z+honda_integra_type_r_dc5+roof_support.jpg (34.8 KB)
open | download - 0608sccp_21z+honda_integra_type_r_dc5+roof_support.jpg (48.2 KB)
open | download - 0608sccp_13z+honda_integra_type_r_dc5+floorpan.jpg (50.2 KB)
CharlieV
April 24, 2008 04:33PM
Maybe that's only necessary on hondas.
April 24, 2008 04:39PM
Oh OK. That's called "double skinning" in the car prep world.
April 24, 2008 06:48PM
Well, overlapping makes sense too. Or Multi layering smiling smiley
How I stitched my car was I started doing everything between the strut towers on the "floor pan/suspension areas" ... then I got bored and needed TIG practice... so pretty much EVERYTHING between the strut towers is done now. Even the roofskin and I drilled out plugs around the door and side window openings.
Yes... WAY to much work. I like the glue idea
