Fuel Lines, pumps
Posted by Tom B
Re: Fuel Lines, pumps
October 30, 2008 11:53AM
david amor Wrote:
> I don't know...expensive as hell but I find kind
> of a zen serenity assembling a/n fittings.
cblakely
Chris Blakely
'92 VW GTI 16v on MSnS-E
October 30, 2008 01:11PM
Ahh Tom, I'm sure you've seen the build thread photos... the car I got needed a lot more work. Your car was well built and well maintained, so you'll be better off in the long run probably. Plus I will definately miss the open-ness of the main hoop in my red car (has the exact same roll cage), as the V-bar design that isn't legal for any new cars, but was at that time, makes for a wonderfully accessible storage net right behind the seats.
http://www.ckrally.com
October 30, 2008 01:23PM
Pete's picture maybe:
To hotlink a photo, you have to put the letters "img" (my quotes) in square parenthesis (brackets []), then the URL of the photo, then "/img" (my quotes), again in the square brackets.
Eddie Fiorelli
Eddie Fiorelli
mk2 VW GTI
October 30, 2008 02:54PM
On hotlinking, I've also found that its space sensitive as well. Don't leave any space between the . I think that's correct..
October 30, 2008 05:03PM
Pete Wrote:
> AN fittings suck... to put together.
> After that, they're awesome. If they don't leak.
I've never had much problem , and none of mine have leaked. Maybe I'm just lucky. smiling smiley Some assembly lube works well as a lube for the bigger stuff. The -3 mandrel from Summit is a must for brake lines. Makes them simple.
October 31, 2008 04:39PM
I tried the BBCode like that and it didn't work. Maybe a space snuck in there or something. Thanks for posting it up.
Line #6 is the key. Curse and return to step 3.
There's a Firebird here that probably has more AN in it than my daily driver is worth and two of the -10 oil hoses are leaking. Both are leaking at the flare and one is leaking at the hose/fitting junction. They are both 150deg fittings in just about the worst possible place to have a leak or have to access. (Pontiac with headers, and it has a thread-on style oil filter to NPT adapter, and guess which two fittings are leaking?)
I've had zero trouble with AN lines until now, but it's time for much cursing...
Edited 1 time(s). Last edit at 10/31/2008 04:40PM by Pete.
January 12, 2009 11:21AM
Found John's setup on ebay for ~$70:
mine came off a MB 300 SE:
only thing I don't like is that the way it is plumbed, The pumps push/pull through one another....not sure how that would affect everything when a pump dies...
January 12, 2009 01:30PM
It's just fine.
January 12, 2009 05:30PM
> It's just fine.
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.jvab.f4.ca
so for a backup to my OEM pump, can I install an aftermarket inline fuel pump as well and have it NOT run, but wire it up w/a switch so if/when the oem one goes, I can just hit the switch and keep on going?
Vorpal_Rally
Stinkfinger Lipschitz
January 12, 2009 06:35PM
Bulkhead fittings as appropriate. The braided line acts like a low speed mill on anything it touches.
It is useless for the sheep to pass resolutions in favour of vegetarianism, while the wolf remains of a different opinion.
William Ralph Inge
TANSTAAFL
vbares
Vittorio Bares
Audi 4k (3b conversion)
January 16, 2009 10:43PM
Here's a pic of my setup - its installed on a 3/8" piece of aluminum, which acts as a skid/crash plate as the setup stays in its stock location under the car.
Each pump is on its own relay and its own switch. Although each pump has a check valve - w/the 10v turbo setup - I tended to run both as it seemed to provide more fuel at 14psi boost.
Now - I have no idea (flow vs. pressure) if turning them both on actually helps or if having one off leads to some sort of bleed back?
The last image, I believe is from one of JVL's rigs...
Edited 1 time(s). Last edit at 01/16/2009 10:46PM by vbares.
open | download - Photo_060708_001.jpg (85.5 KB)
open | download - Photo_060708_002.jpg (78.5 KB)
open | download - fuel_supply_done.jpg (65 KB)
January 17, 2009 12:41AM
Why the check valve??? If the pump is on it's under constant positive pressure, no?
January 17, 2009 01:24PM
Until you start running low on gas...
January 17, 2009 08:41PM
> Feisty Peacock?
If I'm outa gas I got bigger problems. I go out on full fuel ALWAYS.
