jameseshepherd
Jim Shepherd
Location: A few hours north of Seattle in the state of confusion
2001 Toyota Celica GT-S
Re: What are these called and where do I get them?
November 07, 2008 03:09PM
L Stands for low carbon - less carbon in the stainless steel to prevent weld sentitization
308L is for connecting 304L to 304L (Stainless steel to stainless steel)
309L is for welding stainless steel to carbon steel
I had a project (I used to build large chemical plants) where we had a lot of weld cracking from using the wrong stainless steel to carbon steel procedure. Probably not so much an issue with a rally car but I suspect you would not want to cause anything that would potentially cause a crack.
November 07, 2008 03:43PM
^^ cool, thanks...not too much stainless on my car...but can't hurt to pick up a roll. sounds like stainless is the way to go on these weld nuts.
November 08, 2008 02:00AM
Fer cryin' out loud guys, this is all just mental masturbation. All you're doing is just welding these little nut things under the car so you can bolt plastic to them. You're not attatching an engine to an airplane or welding up the cooling tower plumbing on a nuclear powerplant for chrissakes!
Even then these fancy little nut plate things are more money and more work than you need to do for attatching underbody plastic. I always use wide head 3/16" steel rivets (not the aluminum ones.) You will really want to invest in an air riveter for them, though. They don't vibrate loose and fall out and they are flush so they are not so susceptible to rocks. If you want to take the plastic off you gotta drill them out but big deal. How often do you take the underbody plastic of anyway? Not very often.
November 08, 2008 11:55AM
I'm sorry, but what's wrong with masturbation?
grinning smiley
November 08, 2008 12:23PM
This is today over on Turbobricks.com, the best automotive forum, except a few idjits, I know of. It's from a friend in UK:
BB-Q wrote:
One of my sons has recently joined the Merchant Navy as a Cadet Officer. He is off to the Med in a few days for six weeks as part of his portfolio/training (Hoggen can probably explain this better than me).
Anyway, he just showed me this book he has:
WTF? I mean, I know the Merchant Navy's run on very much like the real Navy and I know it must get lonely at sea, but do you really have to keep a record every time you crack one off? :wtf:
I can just imagine how it would be filled in:
I've warned him to keep an eye out for Phillipinos and pineapples. :nod:
27/11/08. Been at sea for approximately three weeks. Was just discussing the merits of Tomb Raider and up came Mr Happy. Quick trip to the toilet and discharge completed at 10.15pm, approx 10cc. Wiped and flushed."
So whaddya think of that?
My answer was:
"Yepp, gits mighty lonesome at sea, m'am.
A man's gotta do what a man's gotta do."
> Jon Burke - KI6LSW
> Blog:
> 'Holy Shit!' @ 4:10
November 08, 2008 12:53PM
> chrissakes!
What...are you a madman??? I full intend to not only die penetrant test all of the weld nut welds but in fact go one step further and x-ray them all too. You just can't be to careful when you attach thin plastic sheeting to the underside of a rusty POS '80's Japaneses econo-box. Peoples lives are at stake here...
I also regularly drive so fast that air friction causes the underside of my car to climb dangerously close to 800F rendering all of my stainless welds susceptible to sentitization and intergrandular corrosion. I studied metalography and have seen first hand how scary microscopic carbide precipitation can be...you just don't know man
November 08, 2008 02:02PM
god that's sexy......gimme that log book.
November 08, 2008 02:23PM
Sadly it's not very useful. All the pages are stuck together...
November 08, 2008 03:48PM
that's just nasty
Edited 2 time(s). Last edit at 11/08/2008 04:21PM by Jon Burke.
Ted Andkilde
Ted Andkilde
1968 Mini
November 09, 2008 01:58PM
david amor Wrote:
> Too much thinking not enough riv-nutting going on
> around here. The force on underbody plastics
> should not be pulling DOWN so the attachment point
> doesn't need to be TOO sturdy. If your underbody
> is getting ripped off you've got other problems.
Also note that there are two convenient holes (or dimples) on these nutplates -- drill 3 holes, place on inside, rivet/repeat.
November 09, 2008 03:34PM
Now you're being redundant. Skip the nutplates, just use the rivets.
Lurch
Eric Burmeister
Mazdaspeed3 and Mazda Protege
November 10, 2008 10:51AM
Riv-nuts won't last 2 seasons. The Protege started with rivnuts. By the end of the second season they were either all tacked with welds or ripped out and replaced with the above style weldnuts. They would become loose and just spin in the sheet metal. Junk. No, no force pulling down, but the vibrations of being continuously pelted by a storm of gravel loosens the rivnuts' grip and they start sucking shortly after installation.
Don't rivet in the weldnuts either. I just tack em on the ends instead of doing pretty ribbons of tig like that photo up there. Just get em in using your mig glue gun and call it a day.
Lurch
Eric Burmeister
The west coast...of Michigan
Edited 3 time(s). Last edit at 11/10/2008 11:01AM by Lurch.
November 10, 2008 11:20AM
What if I just dipped my whole car into a giant can of vinyl???
November 10, 2008 12:19PM
> can of vinyl???
Just keep the wipers and fans going as it sets up, you'll be fine.
Lurch
Eric Burmeister
November 10, 2008 12:24PM
Put a cork in the tailpipe first.
Lurch
Eric Burmeister
