Do It Sidewayz Wrote:
> > Not really launch control, although its fun
> to
> > call it that. It's basically a rev limiter
> on a
> > switch. Activated, it limits engine speed to
> a
> > predetermined launch RPM (no more trying to
> hold
> > revs on a moderately cammed motor on the
> start
> > line). I release the clutch and it stops
> the
> > limiter by the use of a switch on the pedal.
> That absolutely is launch control. Always just a
> rev-limiter activated by the clutch/aux switch.
> Push clutch in....flip "launch" switch, and insert
> accellerator to floor, let the clutch out and you
> go!
> Ofcourse there are fancy pants systems out there
> which measure wheel speeds, and limit the amount
> of power the engine makes to allow the car to
> accellerate faster.
> but 90% of the stuff is just as you describe!
> Chris
Mostly true but with mine (and soon yours
) theres no switch, its active anytime the clutch is depressed and throttle is fully open. I've had it come on when I fucked up a hairpin and had to shift into first. Also it's controlling boost or should I say LIMITING boost so the cars making 10 psi sitting still.
