Wiring Planning and Diagram
Posted by Tom B
Re: Wiring Planning and Diagram
November 07, 2008 01:08AM
Do It Sidewayz Wrote:
> > Not really launch control, although its fun
> to
> > call it that. It's basically a rev limiter
> on a
> > switch. Activated, it limits engine speed to
> a
> > predetermined launch RPM (no more trying to
> hold
> > revs on a moderately cammed motor on the
> start
> > line). I release the clutch and it stops
> the
> > limiter by the use of a switch on the pedal.
> That absolutely is launch control. Always just a
> rev-limiter activated by the clutch/aux switch.
> Push clutch in....flip "launch" switch, and insert
> accellerator to floor, let the clutch out and you
> go!
> Ofcourse there are fancy pants systems out there
> which measure wheel speeds, and limit the amount
> of power the engine makes to allow the car to
> accellerate faster.
> but 90% of the stuff is just as you describe!
> Chris
Mostly true but with mine (and soon yours smiling smiley ) theres no switch, its active anytime the clutch is depressed and throttle is fully open. I've had it come on when I fucked up a hairpin and had to shift into first. Also it's controlling boost or should I say LIMITING boost so the cars making 10 psi sitting still.
November 07, 2008 08:08AM
david amor Wrote:
> Mostly true but with mine (and soon yours )
> psi sitting still.
I haven't looked into that all that much...since i like my trans.
But you could easily fire in another switch so it's only on launch control when you want it.
I don't think it's soo much controlling boost, but when you are bounching off any rev-limiter (even stock) you will make some boost..but that's probably more because of the back fires and shit in the exhaust.
I may however just wire it up to scare the piss out of Timmies Drivethru people.
I've had this idea for WAY too long to go out to the Timmies Drivethru at 3 AM in the middle of the snow storm, and pull the "FIRE IN THE HOLE", in a rally car with Launch control, ALS, etc!
November 10, 2008 02:00PM
Updated images:
see any other issues yet?
I'm going to make a wiring diagram as well so expect that in the next week or two.
any suggestions?
Edited 1 time(s). Last edit at 11/10/2008 02:12PM by Tom B.
November 10, 2008 08:33PM
