v-band clamps
Posted by vbares
Re: v-band clamps
January 19, 2009 07:17PM
> Here's what I reccommend now for slip fit:
> A&A Manufacturing
> Search Criteria: 'header'
> Records/Items Found: 5
> Cheaper even when I order a bunch.
> John Vanlandingham
Isn't there some tim guy locally that could cut a few sheets of these out of mild steel and you are good to go for dirt ass cheaper than the above?
Re: v-band clamps
January 19, 2009 08:41PM
> The two pieces are welded on one on the one pipe,
> the other on the other overlapping and lined up so
> the bolt passes thru.
> It can get smashed to shit and it still holds, and
> the time difference is maybe a second or three.
> And yeah the shape helps, look at it, it helps
> deflect, no perpendicular anything to catch and
> get ripped off.
> You cut your service time so short that a coupla
> seconds difference matters?
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.jvab.f4.ca
> Edited 1 times. Last edit at Jan 18, 2009 by john
> vanlandingham.
And since you're doing some welding anyway you could use a weld nut on one of the pieces and then just zap it off with an impact. That would be just as fast as the springs
Re: v-band clamps
January 19, 2009 09:16PM
Tom B Wrote:
> > A&A Manufacturing
> > John Vanlandingham
Fawk me Tom they're like 2.50 for the cheapest!!!!
Programming time and materials cost something!!!
Hey cheap-ass, what's going on with suspension?
Youse otter call.
> __________________________________________________
> _________
> Fine Tuning | DemonRally
> "If everything seems under control, you're just
> not going fast enough." -- Mario Andretti
