Pin jack stands
Posted by NoCoast
Re: Pin jack stands
June 04, 2009 12:08AM
We use those with our car, they're really nice and SUPER stable. Its nice to have the adjust ability too
krisdahl
Kris Dahl
Integra, Civic
Re: Pin jack stands
June 04, 2009 02:18AM
The main reason we don't have a three/four points are these:
1) We have a lot of surface area with a triangle way, won't sink into the ground like a three/four/normal jackstand>
2) Harder to fabricate
3) Harder to transport. Packing Jackstands is always a PITA.
I have considered putting a leg or extension on it though.
Re: Pin jack stands
June 04, 2009 10:42AM
Why? I think I'd probably find myself always at the highest adjustable point anyhow...
Doug Heredos
Doug Heredos
Re: Pin jack stands
June 04, 2009 11:59AM
I like all the fab photos- You guys do nice work.
Why not just take a normal jackstand and weld a pin to the top? Add some gussets, of course. But then the triangle base and adjustability are done.
That sounds really quick and easy... May not go as high as you'd like, though...
Doug
Re: Pin jack stands
June 04, 2009 12:41PM
> work.
> done.
> Doug
they don't, unless you get the 3 or 4 ton jack stands, which are big, bulky, and frickin' heavy.
lots of options, I wouldn't say anything is 'wrong' unless it falls on you. then that's bad.
Re: Pin jack stands
June 04, 2009 02:28PM
> Grant Hughes
> Denver, CO
Well, When we first started, the car was a bit low, and we had to jack the car, put the front stands in at a lower height, put a 4x4 on the jack, jack higher, and then adjust. Kinda ghetto... but it worked. Also, I seem to remember dropping one or two a notch down, or raising, or whatever, to make up for iregularities, so the car didnt shake.
krisdahl
Kris Dahl
Integra, Civic
Re: Pin jack stands
June 04, 2009 02:33PM
The reason we made ours adjustable is the fact that out in the field with an aluminum jack we won't be able to get as high up as in the shop with bigger jack.
I want to get a low profile, high lift jack, but just haven't done it yet (expensive) that we'll use in the shop and on the road.
The problem with converting normal jackstands is that they will wobble quite a bit, plus you still have to cart around squares of plywood so they don't sink into the ground.
Re: Pin jack stands
June 04, 2009 02:37PM
I started typing that the jack diff was the main reason I could see.
My burly jack will lift like 32" high, but weighs something like 150 lbs. Needless to say, I carry a piece of 4X8 wood to events where I drive the car to the event so don't want to deal with finding somewhere to put the big jack.
I have to say though that I really like yours Kris.
You should share dimensions and such that you went with. smiling smiley
Re: Pin jack stands
June 04, 2009 05:33PM
Oh, FEA Stuff.
so, i did an initial load of a 4000 lb car divided up the force equally between the feet of the stands
and then did it at 10x that amount.
these are the results.
open | download - fea stands ten.jpg (89.1 KB)
krisdahl
Kris Dahl
Integra, Civic
Re: Pin jack stands
June 04, 2009 07:39PM
I'd be happy to. Just have to get my notes (hopefully can read them still!).
One thing for sure though is I'd use DOM tube for the adjustable 'socket' and 'neck'. Was really tough to get a smooth-operating yet not sloppy setup with the ERW square stuff. A lot of filing and grinding, test-fitting.
Re: Pin jack stands
June 05, 2009 11:49AM
> Oh, FEA Stuff.
> stands
> Grant Hughes
> Denver, CO
so that means these would just bend a little if I stacked 10 cars on them? cool.
Re: Pin jack stands
June 05, 2009 12:00PM
I'm going to say, no...
lots of factors here...
Your sockets are angled - chances are the corner wieght of your car is loaded on one single, small point on the pin.
Stands are angled.
Does the rainbow drawing take into consideration the altered metalurgy around the welds? (quality/consistancy of welds?)
Shift in loads and vibration of the car...
etc...
I still wish I knew how to play with a program like that. I probably wouldn't overbuild and overthink as much...
Jon, is the pin just a machined step down? Or, os it chamfered where the diameter changes?
(It's been a while since I read a book, forgive me if the terminology or subject matter is way off)
EDIT: Oops, the "pin" is two pieces... Grant, does the drawing take that into account?
Edited 1 time(s). Last edit at 06/05/2009 12:01PM by Daniel Buehler.
Re: Pin jack stands
June 05, 2009 12:05PM
No, no, and no. I'm guessing.
But the point is that in a perfect world each stand can more than support the car and this helps point to where failure point would be (which is right where you'd expect.)
The one thing that is missing is that if the welds for the pin to stand are poor it will fail there probably.
mothra
Matt Smith
xr4ti
Re: Pin jack stands
June 06, 2009 07:17PM
I think we are going to have a pin stand building party here in North Carolina. Those woudl be trick on the XR.
Matt Smith
Re: Pin jack stands
June 07, 2009 12:32AM
They are nice on an XR. I just have two stands though so I work on one side, then switch to the other. My jack can lift the rear high enough so that I can sit crosslegged under the rear to take of the halfshafts...
