Tubular VW subframes--pics etc
Posted by Josh Wimpey
Josh Wimpey
Josh Wimpey
Sneak the Golf
Re: Tubular VW subframes--pics etc
February 28, 2011 09:49AM
deathmetalscottie
I'm bringing this back from the grave! Any way I might be able to see some pics of the "new" design? Possibly some solidworks files? Really want to lighten the front of the ol' mk3 but not quite willing to cut the front of the cars frame off, yet...
No computer files.... You can find pictures at https://www.facebook.com/album.php?aid=144902&id=281129179600
No cutting any frame components off, this just replaces the K-frame that bolts on to the unibody and holds the steering rack, control arms, and motor mounts...
fliz
Chad Eixenberger
1988 VW Golf #687
February 28, 2011 10:26AM
I still want one of these. If only they didn't cost as much as my car did.
Robert Culbertson
Out of this dumpster fire
March 21, 2011 03:02PM
What thickness and type of skid plates is everyone running? The car we picked up has 3/8 UHMW, and I've noticed a lot of people running 1/4 alu.... which seems like massive overkill to me. Also, I can't bend 1/4in, but I could do two 1/8 in sheets and stitch the perimeter.
Give the n00b some advice please.
fliz
Chad Eixenberger
1988 VW Golf #687
March 21, 2011 03:43PM
My skidplate is .33" and I've had to massage it with a sledge to get it off my oilpan before.
Josh Wimpey
Josh Wimpey
Sneak the Golf
March 21, 2011 04:38PM
1/4" aluminim and even with a 1.5"x0.120 wall H-frame supporting it, we have replaced it several times....
March 21, 2011 05:02PM
fliz
Support the sump guard and you won't have to go insane thick like that.
It is supposed to be protecting the sump, and maybe the alloy gearbox case from ROCKS flying around.
1/4" and support
Good enough for works cars, oughtta be good enough for youse!
2talltary
Tim
http://hightechplastics.com/
July 29, 2011 04:23PM
Skid plates are usually made out of UHMW. I recently got some from a place online. http://www.iplasticsupply.com/materials/uhmw-ultra-high-molecular-weight-polyethylene-tivar-polystone-sheet-rod. I got some .500" and it worked great. UHMW has great wear resistance and very durable. I used to have aluminum as well had to replace them over and over again. Since I've had my UHMW I haven't had a problem yet.
Edited 1 time(s). Last edit at 07/29/2011 04:24PM by 2talltary.
July 29, 2011 04:45PM
2talltary: who're you? Please read the forum rules about identifying yourself.
I thought I knew every rallyista in CA.
gilbrock
Eli Gilbert
91 Galant, 02 WRX
July 31, 2011 11:50AM
in other news, does anyone have a solution for Mk1 rear swingarms that are prone to bend?
July 31, 2011 11:57AM
gilbrock
Yeah: Toyota 8" pick-up axles.
The bearings in them are bigger than Ford 8.8" things, and I've gotten a 4.1 ring and pinion for $10, a 4.3 for 12 bucks and a 4.88 for $137 new...
Of course there were some mods to use it so probably better to start with something that you don't have to turn the motor 90 degrees and lengthen and cut up so much....
(The Rarebit beam can be beefed up like the MKii and MkIII things but depends on not having a fuel tank in the way. Pyramids as tall as you dare welded at the rear box section and circle track derived 7/8" rods to make the thing a 3 dimension part rater than a 1 dimension flexy thang..)
pdxphil42
Phil Meyers
1988 Mazda 323 GTX #214
August 13, 2011 08:41PM
I did that on mine. Lasted great for about 10 rallies. The rear beam tacoed in the last two events, ending up with about 20 degrees of negative camber. But I never tucked the rear arms in like I did on the previous beam. Just find a junkyard with a couple and buy them all. I did that and walked out with 3 of them for $50. Should last me longer than the car.
++phil
Sindelar
AJ Sindelar
91 VW Golf
August 19, 2012 08:24PM
Well the subframe rot took its toll. Glad i was at a stop when it broke. Where do i get one of them fine looking subframes? Its for a 91 Golf. Thanks AJ
