Re: BMW Compact Build
December 11, 2010 11:21AM
Dave,
this car is going to be the king of kool!
Maybe this might fit in there?
http://denver.craigslist.org/pts/2081958322.html
December 11, 2010 11:37AM
Dave,
Geniuses! Oi!
I guess if you merely call it "close ratio" enough and all your suck-buddies don't know shit either and they don't want to hurt your feeling so they call it "close ratio" also I guess that makes it close ratio..
The numbers don't look very close:
Ratios:
1 - 3.72
2 - 2.40
3 - 1.77
4 - 1.26
5 - 1.00
Fairly similar to the "close ratio" gears the Virtually Worthless guys all get stiffies about.
BUT! If could accept a 4 speed-----2nd to 5th look good. Or OK.
December 11, 2010 06:14PM
Come on, dogleg man! Nothing would be cooler than forgetting, throwing it into reverse and doing a backwards burnout at the start of a stage.
December 17, 2010 12:50PM
The dogleg trans might be a cool thing to have, but since I'm replacing the BMW rear end, I've gone up to a higher rear end ratio. As a result, I think the traditional pattern is going to be a better bet & here's my thinking:
ZF S5D transmission ratios are:
1st 4.20
2nd 2.29
3rd 1.66
4th 1.24
5th 1.00
Flat torque curve of the 3.0L will provide 180 ft/lbs or more from ~2500-6500rpm.
I'm anticipating 1st gear is worthless other than for loading on a trailer.
Running the gearing to MPH calcs I see that I can use 3rd & 4th gears from 26-89mph.
So, I'm thinking with the gearing and rear end I'll likely spend most of my time in 3rd & 4th gears as I'm not dealing with a peaky 4-cyl powerband. BMWs are notorious for the "money shift" so my hope is by making most of my gear changes 3-4, I'll cut down on that possibility.
Sean - thanks for the tip on the roof, I may go cut the roof skin off a TI locally. I tried to cut through the pillars but the electric sawzall I've got didn't have the battery to pull that off. I'm sure it'll go through the single skinned roof like butter.
December 17, 2010 01:54PM
Maybe it's time to purchase a gas powered chop saw. Useful for cutting off roofs or fighting zombies.
December 17, 2010 04:14PM
Grant, Grant, Grant, if chins could kill:
Dude you need to keep 'em at a safe distance...
Mad Matt F
Matt Follett
December 17, 2010 07:12PM
That chainsaw doesn't have a functioning chainbrake... it's not safe.
What did I do on the BMW Compact Build recently?
December 20, 2010 01:05AM
Well these things are done (right) finally:
December 20, 2010 10:23AM
John - those look great!!!
More progress pics from the last two weekends:
Billyee
Billy Irvin
December 20, 2010 01:40PM
The car looks great! Cant wait to see it max attacking!
brianallmotor
Brian R. Barton
Mazda 323 BP-T
December 25, 2010 06:23PM
wow... REALLY looking like a competition vehicle now! paint is going on well it seems.
December 27, 2010 11:23AM
After discovering yet another missing ground, she finally roared to life....open headers FTW!!!
December 27, 2010 03:51PM
Congrats! Sounds like its a boy, and what a boy!
December 27, 2010 06:41PM
That's mainly the fault of BMW soft motor mounts and BMW doofus drivers.
Get good motor mounts and don't be a doofus.
December 27, 2010 07:38PM
Hey did UPS arrive with anything for you? Huh? Huh? well?.....WELL!!!!????
