Tool and equipment?
Posted by DR1665
sagsert
Mustafa Samli
Gaylant VR4
Re: Tool and equipment?
July 18, 2006 03:03AM
Fantastic.
Will do.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
EVO III GSR (Stolen)
Rallies are no place for traitors
July 18, 2006 10:32AM
Cordless impact wrench was by far the most used tool once my car was built.
I like a craftman tool set that comes in a molded plastic case that everything fits into, so that you can open it next to the car and not loose sockets etc in the grass while fixing something.
A good rivit gun is nice for replacing mud flaps every few days.
Once the car was built I basically never used grinders or mig welder.
Cordless drill with sharp bits got used a fair bit at service.
Clear Plastic tape in case you roll and crack the windscreen
A window net in case you brake a side window
Make sure you have special tools like socket to fit wheel bearing nut.
Plastic Spatula to remove mud from wheels and other things
Water bottle that you pump up to wash things off with.
hudson
Andrew McNally
July 23, 2006 09:44PM
Princess Autos spot weld cutters are pretty useless.
Andrew M
Onterrible
30ish
PAddy
Patrick McVeigh
Student Loans
July 23, 2006 10:44PM
> useless.
It may be hit and miss (as is anything else from there!). The first one out of this package was REALLY sharp and made quick work of some of the residuals from my first fender removal attempt, so far so good...
hudson
Andrew McNally
July 24, 2006 04:11PM
PAddy Wrote:
> > useless.
> far so good...
Are you making pilot holes?
Andrew M
Onterrible
30ish
DR1665
Brian Driggs
Keyboard. Deal with it.
July 24, 2006 04:23PM
Noted. Seeing a trend.
I used to have this. The day it kicked the bucket was the last time I ever saw all my sockets together in one place. Totally randoms, now. I might as well keep them in a coffee can. Come to think of it, there's a lot of sockets that I do keep in a coffee can... on the GST... on the fender. tongue sticking out smiley
> every few days.
As is a hose, for rinsing the dusty saloon sitting dead in the driveway for lack of effort. winking smiley Pop rivets rule.
That is comforting to know. Perhaps I can pay for materials (beer and pizza are materials, too), I can get assistance in this regard and avoid the initial investment. Capital is tight.
> at service.
I can't believe I don't yet own a decent cordless. What the hell is wrong with me...?
> windscreen
Duly noted.
I thought they were supposed to be rolled up so they don't break? winking smiley
Can't imagine changing a wheel bearing on stage. Do you keep spares in the car as well? It's amazing the sort of repairs rallyists perform on the road.
> other things
Hey! Clever! I'll remember that.
> with.
I think I recall reading an article in a magazine once upon a time where a guy was experiencing overheating problems due to a blown head gasket. He welded a fitting into the water neck and used one of these deals to add more water to the system under pressure while it was hot to keep it from boiling over while staging or something. Clever, imo.
Thanks for the input, Derek.
July 29, 2006 09:09PM
Along the same vein of this thread:
What are some of the tools needed for doing basic fabrication?
Things like making brackets, doubling up mounting points, maybe more advanced things like vw rear beam reinforcement or camber plates.
The obvious would be a welder and grinder.
What else do you guys use to make your balla' parts?
Band saw, lathe, sheet metal brake, bead roller, hydraulic bender, drill press, etc.
I dont want to drop $1500 on a plasma cutter or anything, but if I can pick up an old drill press or something from a local machine shop for a hunnerd or so would it be worth it?
