PAddy
Patrick McVeigh
Student Loans
Re: Xratty sumpguard center supports parts photos
August 02, 2006 06:29AM
> What the fuck is 20 guage?
> Some mythical dimension rel;ated to some mythical
> King's thumb?
Who the fuck knows, it's YOUR americanskie fault I still have to put up with this imperial crap in the 21st goddamn century in Canada, where everything else is in damn sensible metric!
> Speaka metrique sil' vous plait.
> Or at least some decimal thing.
20ga = 0.0359" = 0.911mm
John Cassidy
John Cassidy
Re: Xratty sumpguard center supports parts ready
August 07, 2006 09:28PM
Sexy shiny rally parts! :-) Looks nice John.
Cheers! John
http://www.lastditchracing.com
http://www.triplecaution.us
August 07, 2006 11:56PM
Hey John, I made some extras figuring you'd rather work on sheet metal and labor intensive sheet and just buy some of these things cause the are annoying to fab onesey at a time.
Did I ever post piccies of the jack point/sump guard front mount/towing eyes????
Guess i better.
John Cassidy
John Cassidy
August 08, 2006 06:45AM
Of course you made extra! :-) I haven't seen pics of the front mount or towing eyes.
Cheers! John
August 08, 2006 11:36PM
> Cheers! John
Well here's some more stuff.
Front combined sump guard front mount/jack point/tow eyelet
Rear tow eyelet/jack point:
Alternator mounts in progress:
Alternator mounts in position on block:
Power steering pump mount:
All the stuff:
The alternator and PS pump mounts are to allow the use of the Cosworth 2wd intercooler in the original position, and to be plumbed in with the shortest possible connecting hoses. The 79-93 Saab 900 turbo radiator is used
Of course there are other things too and all of them are on the jvab.f4.ca or the rallyrace.net/journal pages
mothra
Matt Smith
xr4ti
Re: Alt and PS brackets
August 09, 2006 01:20PM
Those brackets look sweeeeeet!
Matt Smith
August 09, 2006 01:30PM
Yeah. I agree. I got all excited when I saw the prototypes back in April. Now I'm even more so.
mothra
Matt Smith
xr4ti
August 09, 2006 04:29PM
I made an effort to "borrow" the prototypes when I was in Seattle a while back. I can't wait. My "creative" solution for a PS bracket seems to be putting stress on the pump shaft. Still it uses a lawn mower pully and has survived three rallies and numerous rallyXs. No I will not post pictures!
Matt Smith
August 09, 2006 04:44PM
You should post some pictures. I'd love to use a lawnmower part on my car. Then I could one-up my friend Steve and his Suba-stein aka Lego Suby.
Suba-stein specs: 93 Impreza shell, 96 Impreza 2.2L engine/exhaust, 90 Legacy trailing arms, rear sway bar, 01 2.5RS tranny, rear diff, 99 Outback Sport rear halfshafts, 2006 WRX front brakes, 1992 Legacy turbo rear brakes.
Edited 1 time(s). Last edit at 08/09/2006 04:46PM by NoCoast.
PAddy
Patrick McVeigh
Student Loans
August 09, 2006 05:17PM
oh boyohnoyohboyohboyohboyohboy...While we're thinking about alternators, and having never run anything other than the stock crappy headlights, is 90A sufficient to handle the car and a pod of 4 conventional-filament (non-hid) lights? Being so close to the arctic circle and all, plenty of stages end up finishing in the dark here...
August 09, 2006 06:54PM
Yeah dp the math, W/v=amp 400w+120w+25 and more for doo dads/14v= lots of over capacity.
That's why I'm doing brackets for the stock 90A alternator. They're good and they're free with every purchase of an Xratty.
PAddy
Patrick McVeigh
Student Loans
August 09, 2006 08:00PM
Excellent - I already have 2 spare alternators then. I suspect I will wet myself with glee if pictures of a rear beam and trailing arm mounts surface soon, which I assume they will at the rate things seem to be appearing...
Richard Miller
Richard Miller
Saab 900T, Mustang now running
August 10, 2006 03:16PM
John is correct that 90A alternator should work quit well. Just use a good battery as the voltage falls off when the alternator get hot. Probably not a problem up near the Arctic circle until this global warming that the shrub says isn't happen makes things warmer.
RichardM
mothra
Matt Smith
xr4ti
August 10, 2006 04:29PM
We have run a few night stages using stock high beams, 2x Hella 4000, and 2x Hella 500 with out seeing any drop in voltage. I would not expect to see it drop even with 6 total Hella 4000's.
Matt Smith
MRWmotorsports
Martin Walter
Nissan 240SX
August 14, 2006 03:36PM
What's the distance between the chassis rails? And what's the drop (rail bottom to mounting surface)? I'm trying to figure out if I can adapt one of these to a Nissan...
-Martin.
