Re: RSF2000 Rally Sport Focus! RWD Revolution
February 14, 2012 09:49AM
Where can we get a legal fuel cell for a good price
You can get some pretty good deals through the 24 hrs of Lemons website.
February 16, 2012 01:17AM
February 16, 2012 01:19AM
I used bend tech pro today how freeking awesome! hoop and front legs fitting the first time rock on!!!
February 16, 2012 03:57PM
Great!
Get some bent up for the poor Volvo.
February 16, 2012 04:11PM
Great!
i told you they where already bent get off the computer and work im not doing the
car alone when you want everything to be your way. I got 300 bucks and it has main
hoop front legs all the link boxs cut and towers???? I'm tired of the car hear it dose nothing and makes no money.
February 18, 2012 03:05AM
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
February 18, 2012 07:52AM
Are you planning on replacing the dash bar with part of your cage? Looks like your covering up the bolts for the dash bar with that half lateral.
Out of curiosity why are you doing the cage now before the suspension / drive train fab is complete? I would think the cage would just get in the way of that work.
February 18, 2012 11:53AM
the bolts are gone and the dash is cut. I'm going to mount the dash to the cage.
4 legs wont get in the way of anything. buying time for my 930 stuff too show up
and time to build the rear knuckles, my hubs came in last night.
February 18, 2012 12:09PM
That looks great William! That bend tech program looks like it makes things much easier.
February 18, 2012 12:25PM
omg sean Its epic I was with in 2 deegrees of perfect each time.
just needs some more calibration and little more playing with on
my part. but talk about saving tube. When you cut your hoop your
like no way this is way too small and it fits perfect.
February 18, 2012 12:49PM
does that program require some sort of output to a bender? or does it just tell you exactly what you need to bend
February 18, 2012 01:04PM
no just meshure and calibrate your bender and it tells you clocking and mesurements.
If you have a bender you can save hrs and hrs. I did the hoop and fronts in 2 hrs. and another hr of fitting.
February 18, 2012 01:07PM
hmm sounds nifty. So would you recommend it for someone with a JD2 bender?
February 18, 2012 01:18PM
its pre set for about every bender from the shark too pro 105 you would love it!
February 18, 2012 01:23PM
nice, might be worth the 275 then!
