Another RX7 in the mix
Posted by MeCalledEvan
MeCalledEvan
Evan Horner
1983 Mazda RX7 GSL
Re: Another RX7 in the mix
January 14, 2012 03:25PM
Adam: My god you kick ass! Thank you, this will make my life a ton easier and finishing the project should now be more attainable.
I will be sure to keep you updated on my progress, and when I'm able (and the car is running reliably enough), I'll drive the Mazda down to Seattle to show it off if you want. smiling smiley
Matt: Now there's a thought. Shit, now I've got a ton of possibilities. This is great. I'm feeling a lot less discouraged.
"The more I learn, the more I realize I don't know and have so much more to learn." - Claude Rouelle, Optimum G lecture June, 2011
pdxphil42
Phil Meyers
1988 Mazda 323 GTX #214
January 14, 2012 08:53PM
Evan...I've got a 79 RX7 with a current spec RA cage in it if you would like to see how to make some of the elements fit. PM me and I can send you photos of anything you need.
"I, for one, welcome our Robot Overlords." - Philip J. Fry
Mad Matt F
As I understand it, your biggest conundrum is getting the rear cage geometry right... And if you don't do towers now... You'll end up with shorty rear suspension...
If you're out of cash to buy the long rear shocks, can't you just weld up an extension for your stock junk? These don't take side load like a strut right... You said you're not going to actually rally it for a while... Build your towers to the lenght you want and weld up a tube with a top pin on one end and a bolt on the other... Add that to stock shock and go crush cones when your done.
Why not?
Matt
Hey Daddio, no top pins if they can be avoided. The Bilsteins he probably will end up with have nice eyelets, my ultra bitchin Stainless top PIN mounts cost $55 each,
cutting up 4 D shaped ears for eyelet mounts costs maybe $4 + a few minutes, and 2 'Omega" shaped strips top close over and keep the mud out maybe $1...
There are extensions available to do the lengthen to the gravel length and that is a good idea...
Even better would for the guy to ask me about what inventory of second hand stuff that might be laying around here that might be pressed into service.
I am eyeballing some second hand stuff for the mighty Sub-a-rat Justie in a kinda "Welcome to Papahood" semi-works Sponsorship deal so don't fawkin argue.
January 14, 2012 08:55PM
pdxphil42
Hey post 'em up here so all the thousands of other lurkers see 'em instead of just one guy...
pdxphil42
Phil Meyers
January 14, 2012 09:18PM
pdxphil42
What are you running here? Some sort of a Rally porn peep show?
MeCalledEvan
Evan Horner
1983 Mazda RX7 GSL
That's where my mind went with it when Matt suggested the extensions.
Correct me if I misunderstand what you meant here, but are you offering to sell me inexpensive used shocks that aren't completely f'ed?
MeCalledEvan
Evan Horner
1983 Mazda RX7 GSL
January 14, 2012 09:26PM
pdxphil42
Phil,
Did you get my PM?
January 14, 2012 11:54PM
MeCalledEvan
I'm suggesting that after you have measured your extended and collapsed lengths and post 'em so i can look what's on my shelf, that then you call and discuss cause I hate typing.
MeCalledEvan
Evan Horner
1983 Mazda RX7 GSL
January 15, 2012 12:54AM
MeCalledEvan
Roger that. Over and out.
Sounds good to me. Thank you.
MeCalledEvan
Evan Horner
1983 Mazda RX7 GSL
January 16, 2012 12:31AM
Hey John,
I had to pull the car out of the garage so that my roommate could use it, and so I haven't pulled or measured a shock.
But... The Mazda FB competition book states that the stock shocks are 548mm max length with 190mm of travel. There's a good starting point.
--Evan
January 16, 2012 03:46AM
The stock shocks have a hell of a lot more than 190mm of travel.
Trying to figure what aftermarket shocks I could use, I worked their full stroke one time. With no bumpstops and no springs, and no Watts to get in the way, the axle rests against the body channel. And I could still compress the shocks.
They're way overtravel for the suspension, in other words. A shorter shock that mounts higher up on the rear could be used no problem. You can't get any more suspension up-travel without heavy body surgery, and you can't get more down-travel without a telescoping driveshaft or longer links (ahem) to cut down on how much the driveshaft moves. IIRC rear travel is in the 9-10" range.
Fox-body Mustang shocks are a direct fit after you narrow the bottom sleeve or widen the axle mounts 1/4", but the damping is all wrong.
MeCalledEvan
Evan Horner
1983 Mazda RX7 GSL
January 18, 2012 12:05AM
Hey guys, I haven't had too much chance to work on the car or cage design lately due to letting my roommate work on his car in the garage combined with the snow we got. That and school and working on the carbon monocoque chassis for this years Formula SAE car.
I'll keep you guys posted when I get time to go back to work on it.
Thanks for all your help so far! thumbs up
January 18, 2012 12:08AM
Unaceptable! You will work on the car NOW!
January 18, 2012 04:16AM
hell i telecommute with my toolbox!
MeCalledEvan
Evan Horner
1983 Mazda RX7 GSL
January 18, 2012 12:25PM
How about we all conspire against my roommate and kill him so I can have the garage back! He didn't need to remove power steering from his FD in the first place!
That way, I can work on my Mazda when it's 11 degrees out. Also I could get it warm enough to start so I can tune the carb better and get it to start when it's freezing.
Shit man, you gotta teach me your magic! That would be an awesome trick.
