aj_johnson A.J. Johnson Super Moderator Location: Pendleton OR Join Date: 01/07/2011 Age: Midlife Crisis Posts: 1,381 Rally Car: 88 Audi 80 |
As was pointed out, you could ... Oh wait, I have data! I spent $306 + shipping costs for my fairly low end VDO gauges. I then had to find a location to mount all of them and almost never have time to actually look over at them during a rally and there is no data logging. A top open class spec Subaru engine probably starts in the $3-5k range for the short block. The ECU is $1k-3k and more money additionally spent on tuning. $1k for a simple digital dash display that simplifies everything and provides data logging is only $700 more than some of the cheapest VDO gauges to do the same thing. Higher end gauges are even more money! So, full blown race car with race engine, probably not a bad or unrealistic investment. Now if you are doing something like this M3 which is basically stock with Reiger suspension and upgraded brakes. http://www.heikkinenracing.suntuubi.com/?cat=7 Grant Hughes |
Well you can impress all the boys.. That is why people do a lot of the things they do, ya know, to impress the other boys. Better latent than never, I guess. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Do It Sidewayz Chris Martin Mega Moderator Location: Toronto, Ontario Join Date: 01/15/2006 Age: Midlife Crisis Posts: 567 Rally Car: E-85 powered Impreza |
Grant is right on the money.
I had a fairly decent gauge set-up before (SPA Dual Digitals). To effectively monitor Boost, Water Temp, Oil Temp, and Oil Pressure. I had to install 4 external sensors just for the gauges. There were more wires going all over the place, as the gauges needed power/ground. An i needed to find some where to mount them. Ditch the factory cluster (which is pretty much useless except for the tach), Ditch the aftermarket gauges, wiring and sensors. Install 2 Aux sensors and wire them into the engine computer. Then run one cable (basically a USB cable) from the ECU to the Dash. Give the dash power/ground from where you just removed the OEM cluster. Now all the gauges and warning lights are in one place. one quick glance down and i can see everything. it's just dead simple. Chris |
Factory cluster has a gas gauge---that's nice, it has a water temp gauge, I like that, it has a alternator change idiot light, and that ain't bad per se.. A VDO oil temp/oil pressure sender can cost from $2-35, a VDO Oil Temp gauge from $5 to 36, oil pressure gauge same.. so for $12 to $100 I haver all the info the co-driver needs to see. How have we survived for so decades without spending $600-1000+? And really, in a era when 99.8% would make better results just learning how to brake more agressively----the single biggest total fuck up most do---doesn't it just seem like better results might be found spending money and time on the most powerful system in the car? Unless of course you want to impress the boys when hanging around... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
John, you trust the fate of your engine to the co-driver?
You may not buy one, but that does not mean they are not a smart buy. Being able to program the thing to turn on a bright lamp if the pressure drops below X psi above X rpm, and so forth for coolant temp, and fuel pressure, I think is a neat thing to have in a race car where your focus should be on reading the grip of the road so you CAN brake hard and late. Yes, this may be a waste of spending for you, but Derik's car already has very good brakes, very good suspension ect. |
I can see the point there, I was more trying to compare the AIM digi dash to other available, cheaper options. In comparing the aim to say an acewell for $300 or any other 100- $300 dash?
Just data logging/ ease of installation? A good ecu will log it all to a usb or memory stick, and I see a few dashes that will plug right into an obd2 port. |
I trust my engine to the guy who built it.. And he trusts, but verifies these: ![]() and ![]() and ![]() And I know him real well.
Oh of course its neat, but but but but..... whatever. Fuck it, I need to raise prices on a everything so i can splurge on neat stuff.
That is a matter of focus. Never had problems focusing.
Well I guess he wants to spend the money.. Most people seem top have, or claim to have, a limited budget. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Hey for $18 you can get a idiot light sender for like 20 psi or even 30psi. 1/8 NPT so its easy. $1000 buys a lot of used tires to burn up driving... John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
In my own defense, some straight lines just can't be passed up.
Ummmm...
Before you go all JVL on my ass, I know... not your pic, not that 'focus', 'stop picking on me,' blah, blah ... I just thought it was funny, in context. First Rally: 2001 Driver (7), Co-Driver (44) Drivers (16) Clerk (10), Official (7), Volunteer (4) Cars Built (1), Engines Built (0) Cages Built (0) Last Updated, January 4, 2015 ![]()
Edited 1 time(s). Last edit at 07/18/2012 08:41PM by Morison. |
wvonkessler Wilson von Kessler Professional Moderator Location: Lookout Mountain, GA Join Date: 02/28/2006 Age: Possibly Wise Posts: 1,127 Rally Car: Colts are in Finland; now '87 325i, '89 325i |
Tim Taylor Tim Taylor Mod Moderator Location: Oakland, CA Join Date: 02/02/2007 Age: Possibly Wise Posts: 622 Rally Car: Mazda 323 GTX |
Remain clam, ma'am. just photos grabbed to illustrate where reliability comes from. Not some cutsie display on the dash... Kinda like many in the machining business won't look at a lathe or mill that doesn't have a big color TV screen... Nice but that ain't the important thing with the machine--- its what ya doooze wif it. And I LIKED the dial in focus and the unimportant thing--some ol iron block---gently blurred with a short depth of field. That draws the eye to the dial. The dial with the nice clear sweep. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Dazed_Driver Banned Ultra Moderator Location: John and Skyes Magic Love liar Join Date: 08/24/2007 Posts: 2,154 |
