911 Carrera RallyCross Project
Posted by BRAIDusa
BRAIDusa
Paul Eddleston
Subaru Outback Wagon EG33, 911 Carrera
Re: 911 Carrera RallyCross Project
April 29, 2014 05:45PM
What an amazing machine. Win a RallyCross Saturday, bolt some street tyres on it, win an autocross Sunday.
Nathan Usher
Nathan Usher
Video
Andrew Wong
Andrew Wong
Paul Eddleston
BRAID Wheels USA www.BRAIDUSA.com
Team Illuminata Motorsport www.teamilluminata.com
BRAIDusa
Paul Eddleston
May 20, 2014 10:43PM
I thought we hadn't done much to the car recently then I looked at my pictures in my phone and thought "oh poop, better do an update". So here it is:
Removed the rockers for weight savings and bad-arse look.
Then thought. I need a bad-arse helmet too:
Then we took some cars to some coffee (cars & coffee)
RallyCross in South Lyon this weekend . Let's see how the new helmet performs.
smiling smiley
Paul Eddleston
May 21, 2014 01:30AM
man I'm a sucker for a red porsche
BRAIDusa
Paul Eddleston
May 25, 2014 09:11AM
Sent the car on a diet again. Removed antenna:
added a foot rest, removed front carpets, removed sound deadening, removed center console, removed ac blower:
The result, -52lbs:
Also adjusted the valves on the right side of the engine, tried to adjust the clutch but I think we need a new helper spring. Adjusted the handbrake.
Paul Eddleston
sackytar
Rob Sackyta
WRX In Progress
May 25, 2014 09:16AM
Looks like you too were on a Diet. You looked paper thin at the RallyX yesterday!! LOL.
Rob
Rob
Devil Bat Racing
Grand Rapids Mi
Planet Earth
https://www.facebook.com/devilbatracing
http://www.robsackyta.com/
BRAIDusa
Paul Eddleston
May 25, 2014 09:54AM
sackytar
Rob
That's so my MFH will look like a BFG when I'm pounding on the car.
Anyway, I only look skinny at car races. At bike races, marathons and soccer matches I look quite normal LOL.
Paul Eddleston
BRAIDusa
Paul Eddleston
June 03, 2014 03:05PM
Well, it finally happened; the RallyCross 911 got beaten in a RallyCross! So now it's for sale. Nah, we're keeping it silly. It did get beaten though but we have an excuse as the clutch was slipping. At least that's Scott's excuse. My excuse was slipping talent. Here's a video of it launching with the slipping clutch. We thought it was tire spin but tires don't smell like that PU.
<iframe width="560" height="315" src="//www.youtube.com/embed/tCDrSl8dz-E" frameborder="0" allowfullscreen></iframe>
So do we need a new clutch? We're not sure. The clutch disc was changed last year even though the old one was only 50% gone, but the pedal has felt funny the last few weeks. We thought it was our inability to adjust it properly but upon closer inspection we discovered the helper spring, the horse hoe shaped one under the transmission was binding and possibly taking some pressure off the clutch plate. It also stopped the clutch pedal from coming back up all the way too. That's all freed up now and it seems to be working but we need to test it under race conditions to be sure. Fortunately there's an autocross own the street this Sunday that will be perfect for such an occasion.
Other than this hiccup we finished cleaning up and painting the driver's side floor which meant dealing with the ECU, handbrake and gear stick.
Just need to source a better pedal plate and passenger footrest. The wooden ones fell apart.
Paul Eddleston
BRAIDusa
Paul Eddleston
June 04, 2014 09:17AM
Some pictures from the last RallyCross courtesy of Nathan Usher.
Paul Eddleston
BRAIDusa
Paul Eddleston
June 19, 2014 02:11PM
A bit of fixing, a bit of improving, then BAM! a whole lot of broken, probably.
We went to adjust the loose wheel bearing last week, the day before the autocross, only to find it was a worn tie rod end instead. Skipped the autocross and ordered up some Turbo tie rods from Pelican. These are what came out. What were you thinking Dr. Porsche?
and the new stuff. An "upgrade" to what every other car manufacturer uses.
Pretty easy to swap in. The hardest part is getting the spring to seat over the bellows but we found rotating the bellows also rotated the unseated portion of the spring.
We also ordered these Rennline foot plates to finish off the interior.
We then sent the car off to the 944FEST to be used for rally demo runs while we visited Niagara Falls with the family. By all accounts it was a big hit. We picked up the car from the venue on Tuesday and took advantage by doing some practice runs for a couple of hours. Unfortunately during this session the gearbox started acting up such that now it won't go into first gear and fifth is a bit stiff to get into as is reverse. sad smileysad smileysad smiley We have yet to get into it but suspect broken syncros but hoping for something in the linkage.
Paul Eddleston
BRAIDusa
Paul Eddleston
June 23, 2014 09:36AM
Hey, we made GRM Reader's Ride of the Week!
Grassroots Motorsports
Paul Eddleston
BRAIDusa
Paul Eddleston
August 04, 2014 04:35PM
Hey, I need to apologize.
Apologize for not updating this thread for a while, I have an excuse: I broke the car. That's not really a good excuse. I could have posted about how I broke the car. Well, I was going to but I realized pretty quickly that I didn't need to race the rest of the year and so I didn't need to fix the car right away so I decided to fix my UR Quattro instead as it hasn't ran for ten months and THEN I forgot to update this thread. Forgive me now?
85 UR quattro - AudiForums.com
So what happened to the Porsche? Well, I think I broke the gearbox during a testing session. It will no longer go into first. There's no grinding or weird feelings. It just wont go in. I don't think I should force it. First was always a bit grindy and we did find some dog teeth on the drain plug last summer if you remember.
During the test session I started using first on one particularly slow corner and it would grind sometimes. Then it grinded a little more then the next time I came round it wouldn't go in. All the other gears work though fifth was very stiff at one point and I couldn't get it out of reverse a couple of times. It's out now and fifth and reverse all work fine.
So what have I done and what's the way forward if you excuse the pun?
Paul Eddleston
hudson
Andrew McNally
August 06, 2014 08:46AM
This is so much awesome.
Andrew M
Onterrible
30ish
BRAIDusa
Paul Eddleston
November 04, 2014 09:57AM
No action on repairing the trans yet. Still working on the Quattro. However, we did move the car into our new showroom area, even though it's not really ready yet.
Paul Eddleston
BRAIDusa
Paul Eddleston
November 09, 2014 02:22PM
The Porsche's new home is finished.
and a friend to keep it company
Paul Eddleston
BRAIDusa
Paul Eddleston
December 28, 2014 04:34PM
Gearbox came apart quite nicely. No horror stories so far. Just a broken synchro ring and stripped dog teeth. The great news is the main bearing races are not loose in the diff housing and no gears look chewed up. I think we will be rebuilding this one smiling smiley
Paul Eddleston
