b00sted
David Barrett
Group 2 Honduh?
December 21, 2012 07:45PM
Anyone want to sell one within the next 6 months or so? I'm looking to get into all of this stuff soon, I figured I'd buy instead of building...Just so I can get out there and race sooner than later.
But, let's say I can't find one for sale that I like and decide to build one...What are some Honda-specific tips or pointers you guys would recommend? I'm going with Honda because I want FWD, and I know Hondas better than I know any other fwd cars(I originally started in drag racing and grew up around Mustangs and F-bodies).
Ideal Motor/Trans, Suspension(does JVAB do Honda stuff?), etc.
Thanks
Re: Group 2 Honduh?
December 21, 2012 08:29PM
There is one on Denver CL right now! Check the for sale section.
b00sted
David Barrett
Re: Group 2 Honduh?
December 21, 2012 08:43PM
Looks like a good deal. There's no way I can make it out there any time soon, but I'll keep his info in the off-chance he still has it this spring.
Re: Group 2 Honduh?
December 21, 2012 09:20PM
There are people in Denver that could probably store it for you. If you are looking now, as you stated, don't let this one get away. That is a steal for a ready car.
Re: Group 2 Honduh?
December 23, 2012 12:19AM
Bummer you're looking now. Evan Moen just sold his supercharged Integra Type R for dirt cheap. He was asking $12,500 last I saw his ad.
But before anyone starts discussing ideal motor/trans/etc... what's your budget? It can range from B18b with a 4.9 final drive all the way up to a 300hp K24 motor with a 6 speed dogbox. As far as a chassis, 96-00 civic is new enough that you can find good shells with minimal to no rust for cheap. 92-95 are slightly lighter. You can go into later year Civics, but if you're going that far you might as well buy a 2012 Civic body in white direct from Honda for $3500.
b00sted
David Barrett
Re: Group 2 Honduh?
December 23, 2012 01:06PM
I don't really have a set budget, but for the first car I don't intend on getting too crazy.
I want to do an EG or EK body(92-00 like you said). Either B or K series, depending on what I can find. I think I'll go the K route, just because they seem to have a tougher bottom end and they make nice power/torque...It looks like they respond well to basic bolt-ons as well.
For a trans, I'm not sure. Nice diff, nice clutch, maybe a final gear swap...Not looking to go to an aftermarket gearset right off the bat...Maybe down the road.
I want a drivetrain that is reliable(as reliable as it can be) and can be competitive eventually.
Re: Group 2 Honduh?
December 27, 2012 10:26AM
Don't do a K-series on a 92-00 chassis. The motor sits 2 inches lower (which means the oil pan does too) to clear the hood. Unless you want to go chasing custom engine mounts and a goofy raised hood and engine. K-series will also cost you twice a B-series motor and you need custom axles for several hundred bucks instead of getting some off the shelf NAPA axles for $100 a piece. Also, for rally you just need a stock motor. Since you don't have a set budget and want to keep it cheap, go for a B18b motor (few hundred bucks), get a B16 trans (another few hundred bucks) and put a 4.9 final drive with Kaaz or OS Giken LSD on the car.
krisdahl
Kris Dahl
Integra, Civic
Re: Group 2 Honduh?
December 27, 2012 01:34PM
Honda sells body in white cars?
Re: Group 2 Honduh?
December 27, 2012 08:09PM
There might be a top spec Honda EG6 for sale soon - 307hp K series, 6spd super short ratio straight cut box, DMS dampers, 4 pot race calipers, floor pedal box, race dash display, full re-wire, etc. Well built and Probably the fastest Gr2 car in the country. TONS of spares.
krisdahl
Kris Dahl
Integra, Civic
Re: Group 2 Honduh?
December 31, 2012 06:51PM
Is that yours? How is the sump clearance on the K-Series? Did you use the stock pan, or maybe swapped out the steel version?
Re: Group 2 Honduh?
January 01, 2013 05:55PM
krisdahl
Its the alloy pan, its better than the steel one because it braces to the bottom of the g/box. Clearance is fine, it does sit slightly lower but still more than enough clearance. Weight is slight less than a B18/20 so no worries there either.
Re: Group 2 Honduh?
January 01, 2013 06:35PM
Are there more pics/specs for that car anywhere?
Re: Group 2 Honduh?
January 02, 2013 12:10AM
Yeah pics on my FB, have to get some on here, but specs I'll have to put them down on a piece of paper and can email.
Re: Group 2 Honduh?
January 02, 2013 10:08AM
Thanks, Timmay has said that a Honda is most likely going to be his next car he's going to build.. That was about 5 years ago and he seems to be a little upset still cause I said he has a nice car now with his AE86 and that was a smart choice and maybe finish it and run it some before talking about "the next car I am going to build"..
Rumor has it's close to done. Maybe only another 4 or 5 years.
RallyTaco
Chris Lanctot
just a wannabe
Re: Group 2 Honduh?
January 03, 2013 01:08AM
When are you and Timm going to fuck and break the obvious sexual tension so we can stop reading this shit on every thread?
Get a room and some lube and spare us the continued online courtship.
[jvl] Ohh noooohs! There's an h'off tawpik thread in the gent-urinal dick-cushion four-hum. THINK OF THE CHILDREN!!![/jvl]
Edited 1 time(s). Last edit at 01/03/2013 01:10AM by RallyTaco.
