DIY dashboard
Posted by aj_johnson
DIY dashboard
January 09, 2013 05:39PM
Need to make a dash for the 80. (self inflicted need) Thinking ABS plastic or some such and rivet it on to a couple square steel tubes for framework. Any caveats or gotchas to a race dash other than making sure wiring is easy to get to?
Be really cool to see some pictures of completed dashboards for inspiration.
Thinking something like this.
One flat panel to for the top with overlap to shade the gauges and another flat panel to stick em in.
I've also got some badass velcro that i'd like to try before riveting.
Re: DIY dashboard
January 09, 2013 10:41PM
Forgot whose car it was, but the panels were made out of Lexan with some black spray-bomb. Light and it ain't gonna break.
Re: DIY dashboard
January 09, 2013 10:42PM
all those relays and switchs.... just looking at Seans wiring, makes me want to start over with some of mine
Re: DIY dashboard
January 10, 2013 12:12AM
Neither is a piece of 032" aluminum..
Re: DIY dashboard
January 10, 2013 08:31AM
Don't have a brake, don't trust myself to make it look good either.
Can I weld dash mounts to the cage? or is that considered a cage modification?
Re: DIY dashboard
January 10, 2013 09:56AM
I'm gonna smack you.
Gimme a call after I drop the girls off at 0835 tell you all the juicy details of those shocks
Re: DIY dashboard
January 10, 2013 10:24AM
You can weld dash mounts in a 'normal' cage. You cannot modify a homologated cage, which ususally doesn't have dash bars anyway.
Rivets are a pain if you have to work on something under or behind the dash. You can drill and use self threading machine screws, dzues fasteners, stove bolts (weld the nuts captive) all sorts of stuff that might be easier to access in the heat of a battle.
Re: DIY dashboard
January 10, 2013 10:52AM
What I've done is use a long bolt, run a nut down and cinch it up and the extra length is not a fixed stud. Place panel over and run a nut down from front side. . easy access and quick and costs a couple of pennies instead of fancy schmantzy dzuz, or cheezoid self tappers.
I am speaking of the fuese and gauge and relay panel above the tunnel to the STOCK dash
Edited 1 time(s). Last edit at 01/10/2013 01:58PM by john vanlandingham.
Re: DIY dashboard
January 10, 2013 01:45PM
Stock dash.
Except Eric B's Mazdaspeed 3, I have never seen one that wasn't stock that didn't look like shit. If you don't care if it looks like shit, then why even bother with a dash?
Re: DIY dashboard
January 10, 2013 02:29PM
Stock dash.
Some rules require you to run a dash...and the Evo dash is heavy, so not a bad way to drop 15 lbs. But it does look like sh!t.
Re: DIY dashboard
January 10, 2013 02:32PM
I'd use the stock dash other than I buggered it pretty bad. Hence the self inflicted need.
johnhuebbe
John Huebbe
1970 VW Beetle & 1991 Subaru Legacy
Re: DIY dashboard
January 10, 2013 02:44PM
My Dash
Out of Aluminum. Can't remember the thickness, but probably .063 or thicker. Just make sure you use a metal prep the sheet before you paint it. Paint doesn't like to stick to aluminum.
Edited 1 time(s). Last edit at 01/10/2013 02:48PM by johnhuebbe.
Re: DIY dashboard
January 10, 2013 02:50PM
johnhuebbe
Dash looks awesome - but that dash bar scares me...though maybe its just the angle of the pic. It looks like you could have some pretty nasty things happen if there was a direct hit on the front corner of the cage and the dash bar deformed in a downwards manner. IIRC, there was a car built here in denver about 10 years ago with a bar in maybe a slightly lower area that was told to cut and move above the steering column (amongst other issues - wavy A-pillar bars being the worst offender).
sidewaez
Blake Lind
orange AE86
Re: DIY dashboard
January 10, 2013 02:59PM
John Reeds looks pretty good, maybe you haven't seen it:
Re: DIY dashboard
January 10, 2013 03:19PM
I used lycra/spandex.
Yes, stretchy fabric. Weighs nothing. Easily removable, as I installed it with snaps/buttons. I added a 1/4" bar across the top of where the dash would be for it to form over.
It works, if you want out of the box. winking smiley
