Sentra SE-R halfshaft sscrewiness maybe?
Re: Sentra SE-R halfshaft sscrewiness maybe?
January 22, 2013 08:54PM
If it ultimately is the halfshafts pulling apart, it might be smarter/quicker to move the strut tops up by modding the strut towers or making an adapter. If I ever get to work on the Starion again, I'll be doing the same with the new longer struts from John; I kinda expected I might have to but planned to do it after I got them in and checked with the approx 1" longer length. Got it planned out. (Never knew I would be so long from any car work.) If that is a possible thing to do, if Gus could posted some pic of the strut towers and tops, it would help. I expect he is trying to get ready for Sandblast which is just over 5 weeks away.
Well "StarionEight eight Seven"eye rolling smiley,
1" shouldn't call for any mods to tower on your RWD thang. Typical is about 1-to 1.25" and Gustavo---who is scrambling to be ready, measured today and said his are a smidgen over +1"
As for the driveshaft thing he said can't be that cause the car drives down the road smoothly and no tugging or pulling....
So we've a) plunged the insert, that works, cool smileyplunged the assembled strut, c) jack the upright/hub/arm without, d) jacked the strut mounted up without internal bumpers and no spring.
goes the whole way..
Ourr current thoughts are is simple: car is much lighter than I was thinking and supplied a spring too stiff
Gus said his last one was like 2200lbs, I was counting on min 2450.
He's going to weigh the whole car and try to get a front and rear weight, I'm going to drop ship some springs. We gotta get this...
January 22, 2013 09:47PM
from my bud's car (same gen SE-R, but with QR25 swap, no cage, no pass. seat, and 175lb him in the driver's seat):
FL: 738 ___ FR: 711
RL: 418 ___ RR: 395
Total: 2262
He claims that the QR (+6 speed tranny) is lighter than the SR20. Or not much heavier. Or something.
All I know is, compared to the 1.6 honda engines I'm used to, the QR25 is HUGE.
Also, I don't know what all might be missing from the car in that estimate. AFAIK, it's not really all that near running or driving yet, so that may be light, or he might have thrown ballast in for a rough estimate.
January 23, 2013 12:35AM
Thanks Aaron that's something and in the direction we're thinking.
Creech
Scott Creech
Audi 90 Quattro (WIP)
January 23, 2013 02:48AM
Well hell, ain't nobody got a big hunk of junk or a Size-XXXL Buddy to throw in the car and see if that weights it down a bit, spot-check?
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
rallyser
John Schellenberg
1992 Nissan Sentra SER
January 23, 2013 02:08PM
The inner joint is a sliding tripod joint from 1991-2001. Pretty much any 2.0 sentra se (1998-2001) or SE-R (1991-1997) have the same driveshafts if they have the LSD transmission (some from 1998-2001 didn't) Gus has a 1991-1993 car as he has in the past.
I had the same issue when I dropped my coilovers out one time. The shaft came unsplined on the outer joint and I had to remove the boot and get it lined up to make it work. The inner joint is the tripod joint and should have enough movement to take 30mm extra length. Gus may have yanked the outer joint out and now it is stuck against the race/cage. He may be able to just jiggle the shaft and have it line up right. May take two people, one to do the aligning and one to push the hub back on to the axle shaft.
January 23, 2013 02:16PM
rallyser
OK sounds good except he said the car drive and no shake or noise...
Does it bind up and prevent up travel??
rallyser
John Schellenberg
January 23, 2013 06:10PM
I don't understand the problem then....
If the "won't hardly budge" issue is related to spring rate or something? If the car drives without vibration then it is not a driveshaft issue. When mine popped out, I didn't realize it until I put the car on the ground and tried to drive off--no go! Shaft just spun and ripped the boot, made some horrrible grinding noises to boot.
What else is there? I'll PM Gus on the SE-R forum and see what's going on.
January 23, 2013 08:45PM
Let's hope it is that simple as the springs!
Hey John, part of the Starion issue with the extra length is that at the new full droop that extra inch is allowing things to go too far out of alignment. I am worried about tie rod bind and such. Also, the strut mount change has nothing to with the length but the fact that the top perches are rattling against a part of the underside of the Starion top mount in a bad way. So I'll fix that and put in a vertically moveable top mount and be able to adjust things in.
rallyser
John Schellenberg
January 23, 2013 09:19PM
What springs did Gus get JV?
I had 300ish on the front of mine and at 2300 including driver it was rough as poo! Even standing on the corner of a car I could not get it to compress, but I knew it moved under racing conditions because the shaft boots got all goofy each time I drove. Gus may be worried about nothing!
January 23, 2013 09:30PM
rallyser
Confirmed at 275 and I think 14", the idea is to run little to no prelaod..that way you get some intial compliance but the rate is a decent one...
I'm thinking if his car is around 2200 like he thinks to go down to 225 and let him wind it up a bit..
What suspension and travel do you have? He has 190mm travel Bilsteins.
January 24, 2013 12:04AM
John, the struts on my old RSX were sprung at 275lbs and that thing weighed 2760lbs. Seems like 275lbs on Gus's 2200lbs is going to act like some pogo sticks. 220's maybe? Will be mucho more grip on the beach like surface of Sandblast next month.
Yeah, I cannot move the front of the XR with all my body weight, 275lb springs, and the car weighs 2800.....
January 24, 2013 12:35AM
Yeah I was deffo Thinking 225.
And no not pogo, well damped but too firm springs
January 24, 2013 12:55AM
You knows I was being sarcastic. I know the valving is spot on.
January 24, 2013 01:59AM
even a prokken clock is right sometimes.
