Hey guys, not sure everyone knows (or cares), but I ended up grabbing Jari's rally car. Flew down to Florida on Friday and drove the car home to Denver, hand controls and all...and yes my arm is still a bit tired! I've now got a real appreciation for how well Jari flogged that car given the transmission.
I'll start out by saying I was 99% sure I'd be swapping the car back to a manual. I bought it with the intention of using it as a teaching car and hillclimb rental in the Denver area, but I've gotten a few messages that if it was kept as an automatic with hand controls there were some folks interested in having some fun in it. Don't worry Jari - I will pull these out this weekend and get them headed back to you, but will take lots of pics so I could replicate the setup. Some folks had ideas about how we might be able to get around the issue, so I was just wanting to re-start the conversation. Currently it needs a new torque converter but before I toss more $$ at it, I'm wondering what it might take to really fix it and get this thing running in a rev limiter punishing fashion. Here's a quick recap on what it's got:
Thanks guys! Dave Edited 1 time(s). Last edit at 04/08/2013 11:44AM by DaveK. |
GM 4L60 uses a 2 solenoid system with PW controlled pressure solenoid. Looks like the solenoid logic is the same, so you could possibly use an aftermarket 4L60 controller!
http://bmracing.com/?wpsc-product=shift-plus-2-electronic-overdrive-transmission-control-for-gm-4l60e4l65e Edited 1 time(s). Last edit at 04/05/2013 12:31AM by phlat65. |
wvonkessler Wilson von Kessler Mega Moderator Location: Lookout Mountain, GA Join Date: 02/28/2006 Age: Possibly Wise Posts: 1,127 Rally Car: Colts are in Finland; now '87 325i, '89 325i |
Look at the TCI bits. We did a thread earlier on this. Here: http://www.rallyanarchy.com/phorum/read.php?5,78553,78622#msg-78622
jrally Jon Rood Elite Moderator Location: Phoenix, AZ Join Date: 10/19/2010 Age: Possibly Wise Posts: 154 Rally Car: '94 Escort GT (sold) |
Or possibly manual control of the box with something like this built for Toyotas, Nissans and Jeeps.
http://www.radesignsproducts.com/Home.php -Jon |
bttmotorsport Jari Hamalainen Senior Moderator Location: Cape Coral, FL Join Date: 12/12/2010 Age: Ancient Posts: 119 Rally Car: Opel Monza, Chevy Monza to be finished 2012, BMW 318 iS |
Dave, it´s NOT electronically controlled... And like said, no way you can drive it on full auto mode... at lest fast anyway.. =)
Here you can see that it´s not really THAT bad... how many would even guess that it´s an automatic without knowing it... Edited 1 time(s). Last edit at 04/06/2013 11:12AM by bttmotorsport. |
So didn't get a chance to take the car out testing this weekend, but did run to the junkyard and pickup a new throttle cable (and got a manual pedal set for $20!), only to find out that the OEM throttle cable was still installed but not connected to the gas pedal. If I'd have taken a 10 second look under the dash when back in Florida, I'd have been able to drive home with a normal gas pedal. In the words of the great Homer Simpson...D'oh!
I did get to drive around the block and the car seems nice and peppy, and shifting it manually as Jari suggested works great...except for the ability to drop it back into 1st gear. I didn't have a chance to see if there were any shifting 'locks' in the higher gears, but it wouldn't complete the downshift to 1st until the revs in 2nd were right about 2000rpm (can drop shift lever into 1st whenever, transmission just won't actually make the shift till speeds are deemed low enough). Been slammed during the week with too much work, but appreciate all the suggestions and help here so far and will try to dig into it further as time allows. Have tech for our hillclimb series this weekend, first race of the season next weekend, Chumpcar race in a yet to be completed BMW the following weekend, and another hillclimb two weeks after that. Time to actually do anything is going to be scarce for another month or so.
You're right that it feels like a totally different car when shifting it manually. When you say its not electronically controlled, are you meaning that there's no external "ECU" for the gearbox like the E36 automatics have? Thanks! Dave |
I have to finish analysis, write, and defend my thesis before Chumpcar also. Cage is almost done, probably will be done or really really close to it tomorrow. Grant Hughes |
darkknight9 Kirk Coughlin Junior Moderator Location: Saint Paul, MN Join Date: 01/08/2006 Age: Possibly Wise Posts: 493 Rally Car: Dreaming of escorts and xrats |
OffTopic: I just had an hour long very positive interview with the prof I might be working with if accepted. I may be moving to Alabama after all. ![]() Kirk Coughlin Woodbury, MN and River Falls, WI Quemadmodum gladius neminem occidit, occidentis telum est. |
bean Rabin Rutten-James Elite Moderator Location: Canada Join Date: 06/13/2007 Posts: 152 Rally Car: None |
Does the BMW 4HP22 have the throttle kick down cable for the transmission or??
Peugeot's use the 4HP22 as well, and it has a kick down cable attached to the throttle linkage. With some fine tuning it should pull 6000rpm on shifts, and kick down to 1st when you floor it and the speed is low enough. If you pull it too far then the cam over centers into WOT mod and it will ONLY upshift at ~6000 rpm... Lots on line with rebuilding them, but I've never seen much on modifying them. Early Peugeot 4HP22's you had to make sure not to rev in neutral or park over 1500 rpm - there was a fix in later years and when rebuilt - but lots of cars got scrapped. Apparently a pretty easy fix now however if you're handy and willing to rebuild it yourself. Rabin |
There´s kickdown wire... but that doesn´t solve the downshifting problem. Also, it is not possible to drive, or yes, it´s possible to drive, but not compete while driving on "D"... For example, when starting on 1st gear tires start slipping, it will throw 2nd in, on 10mph... slipping stops, goes back to 1st and so on... 30 years of competing with at:s, that much i have learned already... =)
Sorry - I should specify that it should downshift when you floor when manually shifting. I agree driving it in D is crappy, but if you manually shift the auto and it doesn't drop into 1st, it *should* downshift when you floor it.
That's how I had to do it with my Peugeot anyway as that was the only was to get it into 1st at speed, and it only did it when I set the downshift cable just right. No idea if it'd work on the BMW version however - just a suggestion. Rabin |
