Re: Need some tips...
July 07, 2013 09:49PM
You want the type of spot weld drill that looks like a little hole saw. Tool Town will have the kit.
July 08, 2013 01:43AM
OK I's a simple minded machinist type, no fixum sheet metal but somma youse ex-spurts straighten me out so I don't make Max mad.. Here's what I's thinking: the crumpled up shit has to go, it's going to get cut out, and replaced with un crumpled stuff.
What's the point in wasting money to pull shit that is gonna get cut out?
Where's Jim Breazeele?
July 08, 2013 09:07AM
It's a judgement call in the end but you need experience to decide. From what I see in the pictures it's probably not worth the time to try to pull it out. I would start fresh at the fire wall. I strongly recommend taking some measurements to see if the rest of the shell is straight. The dimensions are in the Bentley manual.
July 08, 2013 09:41AM
I've done both firewall forward and partials. Sometimes the new replacement parts are more economical than drilling and fitting used stuff (which may be tweaked also). I cut malcolms Talon at the strut towers and had the shell sent to the body shop and straightened to that point. Welded on used inners and core support. Really all you need is a pretty level floor, jackstands, cheap porta power and maybe a come a long or two. I've done complete firewall forwards in the same fashion, no frame shop involved and had cars that aligned fine . It is amazing how much you can get away with and have a car still drive ok at our speeds. 200mph is a bit pickier.
Max
1983 MKI GTI
July 09, 2013 11:53AM
2 hours and the fender finally came off.
im seriously thinking this front end is glued together, not spot welded.
Re: Rebuild
July 09, 2013 05:23PM
I went over and looked at Max's car. Since I have a prior career in body shops and have done what he needs to do on several cars so I have some experience.
The frame rail is pushed all the way back into the firewall. Meaning the firewall is pushed back a bit in that area as well. Possible movement of a-arm rear mount. I recommended stripping everything out of the engine bay and having a frame shop give it a yank. Frame time is not all that expensive and could save him a bunch of labor and headaches. They can measure suspension mounting point dimensions and get the important bits back into alignment. He'll still have to splice in some bits and most certainly the core support but that can be minimized. If he just cuts off the frame rail what he's welding to isn't in the correct place and everything will still be wonky. At the very least he needs to get a shop manual with all the body dimensions and do a lot of careful measuring every step of the way.
Re: Rebuild
July 09, 2013 06:27PM
http://www.vwmotorsport.com/vwtech/jig/Golf%201%20jig.pdf
Golf 1 bodyshell jig dimensions from vwmotorsport.com
Max
1983 MKI GTI
Re: Rebuild
July 09, 2013 09:58PM
some quick 1 person measurements, still need to get the skids off to get a more accurate measurement.
these are all approx..
a=27"
b= P- 14.5" D- 14 5/8"
c=9"
d= havent taken
e=43ish"
f=8.25"
g=7 5/8"
h=58 1/4"
Max
1983 MKI GTI
Re: Rebuild
July 09, 2013 10:04PM
thanks for the link. the bently has an obscured version of some of the measurement points.
Robert Culbertson
Out of this dumpster fire
Re: Rebuild
July 09, 2013 11:29PM
Max, there are a bunch of great articles on this site. A lot of MK1 stuff. There's even a prep section or two. Anyways, you should have fun for a while.
The "Golf 2 GpA Preparation Pictorial" has some devent chassis prep that you might want to do on your car. Especially reinforcing the front horns and stuff.
Edited 1 time(s). Last edit at 07/09/2013 11:33PM by Robert Culbertson.
Re: Rebuild
July 13, 2013 02:12PM
getting it close is all you need, remember, you WILL bend it again, rabbits are bendy.
Max
1983 MKI GTI
Re: Rebuild
July 19, 2013 06:43PM
Anyone have a cherry picker i could borrow?
Re: Rebuild
July 19, 2013 08:01PM
Yeah. But before noon tomorrow.
Max
1983 MKI GTI
Re: Rebuild
August 12, 2013 11:10AM
Donor car resized to fit in the garage...
Motor out of rally car...
I dont have a good feeling about this. Every engine mount is screwed in some way. Either bracket twisted of mounting point twisted.
jrally
Jon Rood
'94 Escort GT (sold)
Re: Rebuild
August 14, 2013 03:35PM
Cars aren't built as precision instruments, people just think they are. Engines and trannies, that's one thing, but the chassis, plus or minus 1/8", not a big deal, 1/4" still not that big of a deal as long as you can get all the wheels into relative alignment.
-Jon
