Noooooob building Audi 4000
Posted by deaner
Josh Wimpey
Josh Wimpey
Sneak the Golf
Re: Noooooob building Audi 4000
August 28, 2013 04:15PM
vbares
I started with the GT2871 - too much lag and the restrictor just chocked the hell out of it, never got more than 24 psi boost. Went to the GTX2860 (Marc has a guy that can retrofit billet cold sides for the GTs) and we were getting into the 28psi range - but the MAP sensor on the ecu was a 2.5bar, so need an 4bar installed so we can get everything from this turbo.
Lots of low end torque thumbs up smiley
FWIW, I have a Gt2871 setup on my 1995 S6 wagon with the same 20v 5-cyl and it is laggy even on the street without a restrictor. I suspect it is because of compressor surge below 3500rpm or so based on the weird shimmering sound (like soft wire brushes on a cymbal) you get at throttle down low and zero boost....Maybe 5-7psi by 3000rpm .....
If you need a map sensor, I have a Varimap new in the packaging (might be a 3.0 or 4.0 bar MAp sensor..... will have to check
One. Class -- 2WD
www.quantumrallysport.com
August 28, 2013 08:33PM
Might be parting my s4 myself. Vems plug n play withls2 coil setup.... lemme know
mke723
Mike Lindenfelser
1995 Impreza L
August 29, 2013 08:27AM
If Your having Davenport build anything, be aware that his work can be hit or miss, and his timelines are, well, on his own time, and very long. I used to worx for a different rally prep team in MN, and we had lots of people call us up after 4 or 5 months of not hearing anything, and no progress, or to fix things the were "less than quality" such as bath tub caulk used in place of weld in hard to reach areas.. it got found at a tech inspection...
There are other cage builders in MN, i am one of them, im a bit booked at the moment, as i have 2 customers cars in the shop getting caged. im within an hour of ya, towards St. Cloud.
Other than that, good luck with your build, and look foreward to seeing another MN guy out there.
I be sorry as a muthafucka I did, still sorry I did n' hustled ta peep what tha fuck I holla'd a lil' bit better, or at least try to.
deaner
Dane Aura
PS4 controller
September 13, 2013 09:28PM
vbares
Looks like someone already swapped out the stock coils - great! I've got two S-cars as DD's - they have their quirks, but if you're handy with a wrench and the internet you should be good to go...mine has 301k mi with an RS2 package. Did a head gasket about 60k ago (in the car). good luck with it...
Thanks! I've always wanted one of these. Mostly for the engine/tranny lol. So far its been nice to drive. My wheel bearings and window have just recently showed up, so Monday I'll put them in. What do you think about 034s stage 1+? I have no real inclination to do much to this thing other than the usually basic turbo car mods. Exhaust, fuel and chip set. Again, future power train while DDing it. Eventually would like to get a VW diesel for DD duty...
deaner
Dane Aura
PS4 controller
September 13, 2013 09:32PM
Josh Wimpey
deaner
And bought this for damn near nothing!!!! $1400!!!!!! Needs a wheel bearing and a window. Figure I'll DD this thing until I can move up a class and then swap the AAN and 01E into the 4k. Always thinking ahead!
Forget that, put a window and wheel bearing in it and sell it for $4000 and use the cash for your 4000....
People buy up these S-cars like hot cakes if they don't have rust or major mechanical issues.
I thought I was lol. Nabbed a future power train for my 4k! Planning on once the wifeys new scooobaru payments get whittled down, I'm getting me a newer diesel truck. Then I'll tear this thing apart and drive a gas sipper to and from work.
deaner
Dane Aura
PS4 controller
September 13, 2013 09:59PM
Sooooo, over the past couple of weeks schedules and weather sucked the big balls. I found another seat for, yup, $100 lol. Love Craigslist! Also ordered up a hub adapter for my steering wheel. Mmmmmmeaning, mounting the seats!
Patched a couple spots on the floor pan and got the seats mounted. My Datsun sold a couple weeks ago... soooooo! Car leaves for the cage next week!!
Drinking a beeeeeer! SITTING in my car!
deaner
Dane Aura
PS4 controller
September 13, 2013 10:07PM
Just stop it. Sssssuriously.
Creech
Scott Creech
Audi 90 Quattro (WIP)
September 14, 2013 01:25PM
deaner
Keep Livin' the Dream, Brotha'!
smileys with beer
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
September 15, 2013 12:18AM
deaner
Too late sold the whole car... get the cage done!
deaner
Dane Aura
PS4 controller
September 19, 2013 12:15PM
deaner
Nice! How's yours coming? Mine leaves Monday for the cage.
September 19, 2013 01:07PM
deaner
deaner
He's waiting for a message later today that I've bent the ears and welded them on his struts.
September 19, 2013 01:29PM
deaner
deaner
YES I AM! Didn't even know I could dance a jig but I did.
Mine is ready for paint when I get back. Need to pick out a roof scoop before I can paint the body but the doors fenders, bumpers and hood are ready.
deaner
Dane Aura
PS4 controller
September 22, 2013 09:11AM
What color have you decided on?
September 23, 2013 04:58PM
my take on the old IMSA 90 paint scheme. I'm inverting a couple of the colors. Nothing too fancy.
deaner
Dane Aura
PS4 controller
September 23, 2013 09:10PM
See ya bitch! Off for a cage today. Gonna order up my gauges next week, get plates/dash podsmade up and enjoy not looking at this thing cage less for awhile....probably the first time this cars seen daylight in like a year and a half!! Also swung the car by my paint guy. Thinking black and OD. I miss having a camo car lol.
