Help me find my misfire before hillclimb in less than 2 weeks
Posted by imnotcrazy
Reamer
Jeff Reamer
Subaru
Re: Help me find my misfire before hillclimb in less than 2 weeks
August 09, 2013 01:28PM
Is it a new battery. 40 out of the last 50 batties Ive got out of these wrecked subarus ive torn apart are junk from the wreck. A lead battery cant handle the abuse of rally the plates move touch and draw them selves dead.
I guess ive said what I wanted to say and will let you sort this out and I hope im wrong but you are waisting your time trying to fix an engine miss with dash wiring. it is a machanical issue so go under the hood. Like I say I hope im wrong and I hope its the heater fuse causing your engine miss.
First rally 2013
Rally car type AWD subaru
Total rallies as driver 6
Total rally cars built 2
Total rally cars caged 3
Like 31motorsports on FB!
imnotcrazy
Don Kennedy
Impreza
August 09, 2013 01:38PM
Optima red top new last fall never been in a rally yet (yes I know all about the abuse they take in rally). I don't understand what it is "mechanical" that you want me to look at under the hood that I haven't already looked at. Haven't pulled the fuses recently. Only so many hours in a day.
Oh, and don't forget, only 12.5 volts at the ECU. Seems like wiring issue somewhere.
Don Kennedy
Edited 1 time(s). Last edit at 08/09/2013 02:18PM by imnotcrazy.
August 09, 2013 06:44PM
imnotcrazy
Don, concentrate on that 12.5 thing. He is probably right on the too much fuel thing, neartly everybody in all cars seem compelled to abide by the if XXXcc/min is good 130% of XXXcc/min is 30% better.
But that hasn't been changed.. Besides your O2 would shopw some hint, and the sparleie plugskies would look like turds if it was some crazy rich thing from mondo injectors...
I ain't the hot guy on electrical shit but by not thinking I usually get it dme---and its usually the simplest thing first and the cheapest thing next...
imnotcrazy
Don Kennedy
Impreza
August 10, 2013 08:28AM
FUEL PUMP!!!!!!!!!!!!!!!!!!!! 25 yr old kid in the garage a stones throw away (Carriage Craft, he and his father and another guy work on MGs and TRs but he went to tech school for automotive and is into Hondas) has been pestering me to check fuel volume, not just pressure. Because of a foul up in my testing procedure, I never got a flow on the Walbro in the car, but I swapped out to a stock pump and got 234 LPH (Walbro is rated at 255 LPH). Pulled great to 7,000 twice. Will need to run the car again to make sure I'm not dreaming but don't want to upset the neighbors again too soon. Will eventually look into some wiring issues but not before the hillclimb next weekend. Thanks for all the suggestions.
Don Kennedy
August 10, 2013 10:47AM
imnotcrazy
FUEL PUMP!
You say that like you only have one in the car... eye rolling smiley
Reamer
Jeff Reamer
Subaru
August 10, 2013 10:49AM
Thats good to here! glad its fixed! Good luck at the hill climb. Engine misses can be a real pain. and is usually simple. again proven to be simple. Sorry I was leading you the wrong way!
First rally 2013
August 10, 2013 11:13AM
imnotcrazy
Figured you checked that--and especially fuel pump ground and volts at pump.
deaner
Dane Aura
PS4 controller
August 10, 2013 12:06PM
Glad to hear you got it figured out. Told ya those effing things cause some weird problems sometimes lol! Guessing your voltage came back too? Good luck at your hill climb!!
August 11, 2013 10:10AM
Good to hear, Don! Been down that kind of road before.....one simple thing. I sure would be running down that 12.5v issue before too long....take a voltmeter and check the voltage right AT the connector into the ECU first though (and inside the ECU if you can get the cover off). Voltage sensors can be off....
