mothra
Matt Smith
xr4ti
Re: Milestone!
November 01, 2007 04:52PM
Bastard!!!!
I already have lexan windows cut and installed for the small windows. I think I may be starting to like big windows. The car needs paint anyway so what's a few more primer spots.
Matt Smith
rallysmurf
alex morgan
'74 bmw 2325i
Re: Milestone!
November 15, 2007 10:23PM
> The car fucking rips now above 3000 RPM. But the
> gearing is such crap that it is a bit of a bore.
> But new gearbox will take care of that.
> Grant Hughes
> Denver, CO
have not been here is a while.
so you went with a dogbox. i'm spiked for you. gfroce? 2.95-.9?
this winter i am back at it a bit. got a 4.45 r&p.
now i am looking for a 2.95 t5 i guess. but.....
still want a quaife.
alex
__________________________
i'm in texas panahndle,
full of gas and oil wells
to slalom.
http://bcdracing.com//pics/rally/rally.html
Re: Milestone!
November 16, 2007 12:39PM
I've got everything so far but the box. Keeping my eye out for a good case and am planning to go with the G-force setup.
I'm hoping they have some of the straight cut 2.95 1st dog engagement kits left. Otherwise it becomes helical only as the option and then I have trouble deciding between the 2.46 straight cut or the 2.92 helical dog kits. I plan to stick with a high 5th gear for the time being though since I'll probably be driving the rally car to and from CORE and events at the beginning.
Planning to order it in mid to late January so I still have a bit of time to contemplate.
Going to shop tomorrow to work on car. Finish Jetta bumper mounting, Cossie headlight mounting, jetta lights wiring, pin jack receivers in sill, and cossie grill mounting.
Re: Milestone!
November 21, 2007 08:35PM
Finished wiring Cossie headlights and VW Jetta fogs and blinkers in bumper. Cut hole and built cold air intake. Holy fuck, thing hauls ass with just a cold air intake and 3" exhaust. Had trouble keeping it straight a few times.
open | download - Image004.jpg (19.2 KB)
Re: Milestone!
November 22, 2007 07:10AM
Grant, is this a T5? If so, can you share link to these gearsets?
Thanks,
Mark B.
Re: Milestone!
November 22, 2007 08:47AM
G-force is the company name. Search for G-force transmission and it should come right up.
Re: Milestone!
December 04, 2007 05:50PM
Here's pictures to show the slight rubbing of brakes as well as how fucking sick they look with the burly JVAB suspenders in the background.
Some burly 7/16-20 press in bits are only $4 per so that looks to be the route I'll take. Have to take apart my spare uprights to send just the part that needs that pressed in taken care of as well as put in some nice M14X1.5 wheel studs and new bearings.
open | download - rubbingbolt.jpg (29.1 KB)
open | download - caliperbolted.jpg (42.2 KB)
Re: Milestone!
March 09, 2008 08:45AM
Worked on my car for about 7 hours last night. Mostly and nearly done, yet feels so far away.
The two coolers in the front are for oil (driver's side) and p/s fluid. You can see the Honda remote reservoir on the passenger side as I'm using the Thundertird remote p/s pump as I couldn't get the lid off with the Bailey reservoir. The four line remote oil filter is also over there with a AN-4 outlet that will feed the turbo, and the stock turbo oil feed location now has a pressure sender. The oil temp sender is on the filter feed as well. The radiator is about 3/4" behind the cross support bar, which in the near future will serve as part of the front skidplate mount. All the passenger side coolant lines have been eliminated and a coolant temp sender was put into the lower intake manifold. I'll have to relocate that some day if/when I get rid of coolant going through the lower. I have a stock lower, and a gutted upper which will likely make for less than ideal flow, but for now huge, optimal power isn't yet the priority. Chuck W motor mounts, ATR header, and .63AR turbo on the passenger side. My planned AN fittings are not going to work with the manifold so I have to figure out a oil return from the turbo. Am going to chop up a wastegate bracket to make an additional turbo support on the top of the turbo to valve cover this week sometime additionally hopefully.
Re: Milestone!
March 09, 2008 12:53PM
So you're not selling it?
Re: Milestone!
March 09, 2008 04:12PM
It's technically always for sale. But no, I am not selling it. Wife won't let me. I'd explain why I listed it, but it's personal. smiling smiley
Put on the whale tail today, and worked on a bunch of other random stuff under the hood. Back to the waiting for parts to arrive game for the moment. And have to figure out if this p/s pump will work.
Re: Milestone!
March 15, 2008 03:41PM
Just put the arches and side skirt on to take a picture for the CHCA program. Still have to fit them properly, as well as a bit of work to make the front bumper look cleaner. But it's a rally car, clean lines disappear quickly when you hit things, so I probably won't put too much effort into it. I love the first picture though.
sagsert
Mustafa Samli
Gaylant VR4
Re: Milestone!
March 16, 2008 10:20PM
Purrrrrdyyyyyyyy !!! grinning smiley
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
EVO III GSR (Stolen)
Rallies are no place for traitors
Re: Milestone!
March 20, 2008 12:22AM
You got that right!
Hey Grant where did you get those springy hold down thing-things for your rear hatch? And what are they really called?
sagsert
Mustafa Samli
Gaylant VR4
Re: Milestone!
March 20, 2008 12:42AM
They are called Terry Springs, SPARCO Part#01608.
Here, this guy has one pair for sale http://cgi.ebay.com/ebaymotors/Sparco-Racing-Steel-Spring-Hook-Fastener-Hood-Trunk_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ6779QQihZ016QQitemZ260216088108QQrdZ1QQsspagenameZWD1V I don't know who he is.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
Edited 2 time(s). Last edit at 03/20/2008 12:56AM by sagsert.
acrane
adam crane
corolla GT-yes
Re: Milestone!
March 20, 2008 02:36AM
homely.
what ever you obsess about in your boat AHAB.
"I put the hurt on dirt" - adam crane
http://CraneRallyCrew.com
corolla gt-s "Patches"
Op: S.S.
