Snidewhips
Jeremy Livingston
1990 acura integra, 2010 Hyundai Genesis Coupe
Re: Stitch welding 1991 Honda crx before or after cage?
October 28, 2013 11:41AM
Anyone glue instead of stitch weld with unibody/aircraft glue??
All bridges burnt, island life is beauty
October 28, 2013 01:51PM
You mean like the car manufacturers? Like the stuff we are removing so we can weld properly to make it last longer and be easier to repair?
Snidewhips
Jeremy Livingston
October 28, 2013 02:23PM
Exactly, more cowbell
October 31, 2013 11:59AM
From a guy that built up an EK honda. I caged it, then stich welded it.
I didn't do anything to reinforce my front subframe or rear subframe control arm mounts but I did stitch weld both sub frames. Haven't had issues with tearing on LCA mounts. I did plate the tops of both shock towers.
I can get you build pictures from my special stage thread, but won't be until I get home.
Edited 1 time(s). Last edit at 10/31/2013 12:00PM by BillyElliot.
Snidewhips
Jeremy Livingston
October 31, 2013 02:15PM
Thanks for the heads up billy, I do have your build book marked and am going to go cage first, I'm awaiting this partner I. Crime to give me a date on liq nit the seam sealer out and don't wanna wait. I'm trying to figure a way to put in a dash bar and front strut mount bars to the dash bar but there's so much damned stuff on this little firewall making a straight or triangulated to be beneficial is almost fruitless..I'm thinking downward to the cage feet.. Had. Bit of a break installed gas and upgraded electric service to weld. Back to it tonight.
