1991 Civic (re)Build
Posted by Aaron Luptak
Re: 1991 Civic (re)Build
December 20, 2013 07:17PM
Rally car says, "Merry Christmas!"
Drained the 2 quart gearbox:
I'm now even less surprised that they finished their last event with fewer gears than they started...
Creech
Scott Creech
Audi 90 Quattro (WIP)
December 20, 2013 07:55PM
Fewer forward-speed ranges... more "gears"...
(or at least pieces of gears!)
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
December 23, 2013 10:38PM
Just a little dent in the header:
Ok, maybe not so little:
Everything but the engine mounts are unhooked - time to round up a hoist and get this lump outta there, at least temporarily!
December 26, 2013 09:37PM
Fun with dear old dad
Engine's out, guess I better get busy with the real work.
December 28, 2013 05:04PM
So two trannies walk into a bar...
December 28, 2013 05:26PM
You can repair those dents in the header ya know...And maybe you better think about double skinning and making a skid for the things, eh?
December 28, 2013 08:51PM
Recommended method for fixing 'em? Probably gonna try the water + freezer (or leaving them outside...) approach for a bit.
Definitely thinking about double-skinning 'em. they're covered by the skidplate, so gotta figure out why it's not doing its job.
December 28, 2013 11:10PM
Gonna need Oxy-Acetylene torch, rosebud tip and a maybe half inch bar.
You look where the baddest dents are drill a hole on the back side roast the dents till bright orange and pound them back out...
Then weld up the hole carefully. Gotta get it hot, gotta hit it...done it on bike expansion chambers. Works pretty damn good.
Paddy1337
Tim Patrick
Galant VR-4
December 29, 2013 02:13AM
is that a big crack on the right bell housing?
December 29, 2013 11:03AM
Paddy1337
No, the big crack(s) is on the left one, right where the two halves meet.
There absolutely is a crack on the right bell housing though. Hopefully will be able to have a bud zap that back together. "Luckily", it's just on one of the very bottom mounts, so it's not the end of the world if it can't be fixed - nothing's going to leak out of that crack.
December 30, 2013 09:40PM
One of these things
is not like the other
Funny thing is, that's better than I expected it to be. eye popping smiley (Was lead to believe that maybe only 1st and 4th were intact. Turns out a bent up shift linkage will do that to ya...)
Yes, those are gear teeth in the bottom of the case.
Luckily, I can pull all the parts out of the cracked case, and swap them into the good case (with the buggered internals). But, I'm seriously thinking of just picking up one of the other transmissions (ITR/Del Sol VTEC/99-01 Si) that I'm planning on running long term instead... Tweak my clutch pedal to be hydraulic, get one new transmission mount, and I should be good to go - aside from actually finding the transmission.
Snidewhips
Jeremy Livingston
1990 acura integra, 2010 Hyundai Genesis Coupe
December 30, 2013 11:22PM
aaron i have a 99 sir trans and axels with 140 000 km in good shape for 150 bucks. no slave cylinder though. if you wanna pay shipping you can have em. pm me if you're interested smiling smiley
All bridges burnt, island life is beauty
Snidewhips
Jeremy Livingston
December 30, 2013 11:23PM
its usdm btw. no lsd
December 31, 2013 12:42AM
Snidewhips
pm'ed.
freakin' enablers. smileys with beer
January 09, 2014 11:31PM
beginning to really understand some of the build vs. buy tradeoffs...
"hey, let's splice these things into the wiring harness such that there's no physical way to remove the harness without cutting either sheet metal or the wiring..."
eye rolling smiley
(yes, these sorts of considerations are a bit more obvious when there's nothing left in the engine bay...)
