Lets see how much flack I can crank up with this, now with 50% more cylinders!!!
Posted by mellow65
mellow65
Oliver Klozoff
Nada
October 26, 2013 06:30PM
so been driving and loving the cluster EFF of the mazda/suabru thing I built. But I say I need more. More you say, sure why not more. 50% more!!!
So why not an SVX motor. Sure, sounds good to me. smiling smiley
Figured out the exhaust, pan, and steering shaft. I just sorted out, at least on paper, the wiring. I'm getting a full car to start with and get all the wiring for it.
Should be fun! grinning smiley
Snidewhips
Jeremy Livingston
1990 acura integra, 2010 Hyundai Genesis Coupe
As long as you stay away from the svx trans they sir are junk.
All bridges burnt, island life is beauty
mellow65
Oliver Klozoff
Nada
Re: Lets see how much flack I can crank up with this, now with 50% more cylinders!!!
October 26, 2013 07:21PM
Negative, I use a W58 out of a celica.
October 26, 2013 09:25PM
Proof positive that all babies should wear helmets. Helps when they get dropped on their heads...tongue sticking out smiley
mellow65
Oliver Klozoff
Nada
October 26, 2013 09:40PM
Also proof positive that most anything will fit in the engine bay of a RX-7. grinning smiley
October 27, 2013 12:26AM
It will sound much better than a rotary anyway.
October 27, 2013 02:11AM
How do you change the sparkplugs?
Tsk tsk tsk. Troublesome details..You're harshing the mellow, dude.
Eric Ewert
Eric Ewert
volvo 240
Soooo.. downdraft carb or throttle body setup???
EricW
Eric Wages
2002 WRX
October 27, 2013 09:46AM
That's actually a good question for Anders as he shoved the H6 inside of an old GC/GF-chassis Subaru with essentially zero room between the frame rails. My guess?
Jackstand under engine /trans. Loosen all engine/trans mount bolts. JACK CAR UP!
Eric Ewert
Yeah this is all about cheap power so a couple of 48 IDAs or IDA style ITBs that'll be nice and cheap only $3000-4000..
mellow65
Oliver Klozoff
Nada
October 27, 2013 10:04AM
Eric Ewert
Just going to run the factory EFI set up. This long block I got for basicly free, I jut wanted to see if it was possible.
mellow65
Oliver Klozoff
Nada
October 27, 2013 01:12PM
in all honesty the motor would probably have to come up a few inches to do it. but i'll make sure some new ones go in before I put it in for the last time.
October 27, 2013 02:56PM
It's a Subaru. To do anything, you first remove the engine.
FHI have fortunately seen fit to make this a trivial task.
buerckner
Andrew Buerckner
Daihatsu Charade GTti DOHC Turbo, and Mazda MX-5(miata) Turbo(bent)
