Welding to cast iron on regular jack stands for pin mount.
Posted by czwalga
czwalga
steve czwalga
95 awd celica
November 01, 2013 11:20AM
Alright... I really didn't think this entirely through before I did it, had off work today and had a 'doh' moment. The reason I wanted to do regular jack stands is that they are adjustable.
Anyways, I'm going with the better safe that sorry approach on this one. 1" solid pin. I've seen some of others pinmounts and they just look sketchy to me. I want to be able to use it for everything not just changing tires at service.
I was going to notch out the U on the jack stand weld it; then put a 1/4" plate over the top to kinda box it in. So I started grinding the material out, just realize hey this isnt steel. It's cast iron. I did some test welds, 220 machine on full power and I was getting pretty good penetration. Pre-heated with a map torch. Honestly it welds like steel, maybe a slight more spatter.
Now the welds will look good but that doesn't mean they are... just looking for a little reassurance haha. I guess I could always do it and drop the car from 4" if it holds were good type of thing.
Edited 2 time(s). Last edit at 11/01/2013 11:54AM by czwalga.
alosix
Jason Powers
Re: Welding to cast iron on regular jack stands for pin mount.
November 01, 2013 11:45AM
I dunno if I'd crawl under it smiling smiley..
There are some decent ones I found that had mild steel parts that could be welded to. They were $60 each IIRC and your could buy extra inserts for them.. Must dig them up. Would run about double the HF 6 tons that would be about the right size for this job.
This isn't floor mat anarchy
czwalga
steve czwalga
95 awd celica
November 01, 2013 11:54AM
Yeah thats actually what i'm using the HF 6 tons.
November 01, 2013 12:18PM
I've seen people just rest the bar/tube/pipe on the jackstand, no welding. That way you can still use them as normal jackstands if you want.
czwalga
Been nice knowing you.
Hope the will is in order, at least tell your family why---survivors always wrestle with the "why" when people kill themselves, so tell them why you want to die, tel them it's you, not them...
See you in the next incarnation.
Like oum dood.
czwalga
steve czwalga
95 awd celica
November 01, 2013 12:30PM
You have a good point. I'd essentially be doing the same thing, just holding the pins in place with the weld. Even if the weld did happen to break its going to catch itself.
JVL, haha thanks for the eulogy. What pete said makes sense, I dont think it should be any probem, would just be like insert the 1" pin without it being connected to anything and setting the jack stands under it, except it would just be secured from moving around.
November 01, 2013 07:50PM
I always thought it'd be a good idea to tack a couple big washers on the bar to locate it on the jackstand so you don't have to have several inches sticking out. 1" ID washers are maybe 75 cents a pop at the hardware store.
November 02, 2013 12:27AM
Plus, might keep the bar from slipping off the stand if bumped, which could be a bad day. But I think that you should do it the right way with custom stands.
November 02, 2013 03:52PM
I like Pete's idea with the washers but would instead use two 3/16" side plates that extend downward and outward from the 1" pin by 2" or more and through which the pins stick; weld the plates onto the pins. These will 'bracket' the 1" pin on either side of the top of the stands, and you could even do a light tack of the plates to the stand. The reason to use these heavy side plates is that they will make the pin set on the top of the stands in a very stable manner, and restrain the stands from tipping over sideways if the car is bumped.
I assume JVL's warning has to do with the uncertain grade of the iron, but he is not very specific on that point.....
EricW
Eric Wages
2002 WRX
November 02, 2013 07:40PM
Make your own insert for something like this:
http://www.northerntool.com/shop/tools/product_200358558_200358558
November 02, 2013 08:23PM
God it should be evident.
Iron is notoriously difficult to weld.
Big herking fat iron and a 1" bar sounds evebn worse than just welding a crack.. Shape of part to be made could not be worse if you tried: vectors, resolving loads, embrittlement, penetraition, consequenses or any of these being wrong, or several, or all.
Iron has its uses, and is good for a lot of things but getting welded on isn't one of them..especially by inexperienced welders used to the ease of steel.
November 03, 2013 11:45AM
Thanks John. I really do appreciate good info; it's not evident to me (and probably to many) as I have never welded on iron. I once brazed up a crack on an old Ford 292 cast exhaust manifold.....but that's the extent of it. Regards....
tdrrally
edward mucklow
November 03, 2013 02:40PM
what about making a new part that slides into the stand and has the pin for the car ?
you could use steel and know its safer to a level.
or fab a new stand that is purpose built for the job
like this
http://2.bp.blogspot.com/_aQZI2Ch3jho/R1PK8ntqNdI/AAAAAAAAAfA/eQgi9T2mCJk/s1600-R/Rally%2BGB%2Bservice%2Bpark.jpg
i would bet steele solutions could make something up to the job
Edited 1 time(s). Last edit at 11/03/2013 02:42PM by tdrrally.
November 03, 2013 02:44PM
Well shit, I forget that sometimes. believe or not there are good electrodes for stick welding iron with no pre-heat or post heat.. My own heads on my Saab have a big herking cast dubble outlet welding where the original siamesed single outlet was milled away.
Cold welded with no pre or post heat
This is fun to see what was done so the little pushrod V4 could go and fight with nasty Fords and Opels,
Ported OEM head:
Group 4:
See the weld?
Done cold.
czwalga
steve czwalga
95 awd celica
November 25, 2013 07:46PM
Fyi if anyone cares how they turned out. Probably overbuilt, I went with a 1" pin, but very little weight difference on the car. Rather not have to worry about the pin yielding of something gets dropped or whatever.
Edited 1 time(s). Last edit at 11/25/2013 07:50PM by czwalga.
