DexterVW
David Baker
95 GTI TDI
My rally car build: Mostly Photos
December 09, 2013 12:13PM
I'll start out by saying I enjoy the building as much as I do the racing, and i'm a picky ass engineer, and I'm doing this on a shoe string, and and and... comment, poke holes, poke fun, but its mine and I love it
how it all began: The test mule (circa 2009)
the previous incarnation towing the newly caged chassis home from Cagethis.com (2009ish)
The car really didn't receive much work for the first few years as I went through a divorce, 5 moves (one across country) and a bunch of other stuff.. but
Then I rebuilt the motor, a 1.9 TDI AHU with some fancy Nural Pistons and a sweet port and polished head and manifolds
Eventually it was time for a new roof
A raised shifter
And Paint!!
Then some seat were installed
and some more engine building
and chassis prep/suspension install
DexterVW
David Baker
95 GTI TDI
Re: My rally car build: Mostly Photos
December 09, 2013 12:14PM
and more....
and finally the engine was installed in the chassis
and it was assembled as I could get it in a day
but because i was doing this (moving back to New England)
along the way this happened
which lead to this
and a long set back of $$, so i toiled away with this
until i eventually dug the beastie out from hibernation for some of this
until my landlord called it a demo derby car and asked that I remove it before the neighbors complained... so off to a new home she went
and then a bunch of stuff happened :-D
I took the brakes off the car i bought for my GF to start racing in
I got a completely new cooling system
and started installing parts as they came
I made some VW to Subie adapters
and bolted up some rocking wheels
and I continue to rock forwards as fast as I can being an hour and a quarter from my garage
December 09, 2013 01:03PM
You must paint the wheels some nice bright contrasting color.
Black wheels are not allowed.
December 09, 2013 01:54PM
You and i competed awhile back with NER, i want to say it was my first event at the dog track? I remember you had a set of axles on the ready lol. the new car looks greta, keep the pictures coming.
tdrrally
edward mucklow
December 09, 2013 02:35PM
looks good, wheels need some colour for sure
Creech
Scott Creech
Audi 90 Quattro (WIP)
December 09, 2013 05:07PM
Black contrasts with Everything: even Black....
tongue sticking out smiley
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
danster
Haggis Muncher
VWs (for my sins)
December 10, 2013 10:35AM
Good to see you embracing the 5 stud suspension and driveshaft components. It's stronger than the 4 stud stuff in various ways so hopefully that will reduce any failures and possible DNFs.
Have you considered any upgrades for the engine mounts? Standard ones are a bit flexi with the hydro style mounts. There are a couple of options to hold the engine in place more securely.
I notice from a pic that it looks like your timing belt tensioner has been rotated the wrong way to tension the belt. It should be rotated clockwise and have the two pin holes normally sit 180deg from where they are now. Even with one in my hand right now I can't work out if having it the wrong way may impact on how the belt keeps tension.
There is a clutched alternator pulley that may be a beneficial modification as it reduces the flywheel effect of the spinning alternator on the over run, the crank nose keyway has been known to fail with so many ancillaries being driven off it. On that note it's particularly important that the crankshaft pulley bolt is fitted in the correct manner.
What engine code is yours? It looks to be an AHU with that type of inlet manifold. I understand some later versions of this engine have a better design of crank keyway.
DexterVW
David Baker
95 GTI TDI
December 10, 2013 01:21PM
danster
Thanks so much for the feed back! Yes I'm hoping the 5 lug stuff holds up to my abuse a little more than the 4 lug stuff... I didn't earn my "breaker boy" nickname for nothing. I blow about an axle an event when i'm really rocking and I've bent a few control arms while I was at it. My worse was two vw's on the sidelines at a rallyx... with the same cv blown. i'm going to try JVL's idea of a simple plastic clip on steering limiter as well... but I do like my opposite lock and seem to break them more in large radi turns with a bump at the apex coupled with full throttle :-P
For the mounts I've replaced the stockers with hockey pucks in the front and engine mount and the trans mount is the corrado g-shitty one which is sans poop. I hope that holds it all together but we'll see after I get it rolling.
I'll check the tensioner.. i know i've taken it off a few times since that photo but who knows if its been rotated the right way. (it made sense when i did it cause I remember debating it in my head, its got the auto tensioning spring feature in it) I might have to crack the manual open for this one. EEK!
Yes the crank pulley does scare me after what happened to my buddies daily driven TDI (yes AHU). I've shimmed mine to take out any free play between the two mating D shapes (.002" shim stock) and I hope that that takes the chance of it rotating and deforming the D's with the impacts of the accel/decel. I will be watching it like a hawk and worse to worse I will be pinning the pulleys to the crank.
Thanks again.
DexterVW
David Baker
95 GTI TDI
December 10, 2013 01:23PM
thanks.. i will deff keep em coming. I look forward to getting back in the action as soon as possible. With more axles at the ready.
turoc
Ozgur Simsek
working on a Veedub
December 12, 2013 10:00PM
Looking good. What top mounts are those?
DexterVW
David Baker
95 GTI TDI
December 13, 2013 08:03AM
Those are Burmeister Engineering Plates.
DexterVW
David Baker
95 GTI TDI
May 23, 2014 10:32AM
She Runs!!!
May 23, 2014 01:23PM
He fussed about the rally shell and not the VW van??? Weird...smiling bouncing smiley
Max
1983 MKI GTI
May 28, 2014 06:24AM
sigh. i miss my vw. i need a project. my garage is empty. and i feel less of a man having it that way.
DexterVW
David Baker
95 GTI TDI
May 28, 2014 06:42AM
Everyone needs a project car in there life... teaches them that no matter how hard you try in life, there will always be something more to do ;-)
