p0inT92
Thorkild Mathiasen
Maybe a Lada..
Re: Rx-7 Rally Car v3.0!
April 07, 2017 04:56PM
Ok, maybe you had a 3.35 gear set, which you can get a 0.9 5th for, which also works with your gearset, but is only convert your 5th from 0.76 to 0.80!
April 07, 2017 08:39PM
maybe it is a 3.35. I need to get back under the thing and see what the tag on it says.
April 08, 2017 06:00AM
The only 2.95 Ford was the "Z" aftermarket box and the early NWC boxes.
If you got the box from a junkyard, it's going to be a 3.35 if it's a WC and 2.95 if it's a NWC.
May 16, 2017 10:15AM
Should be picking the diff up from Wier in a couple of days. Then I can put the rear end together and finish up with that mess.
June 13, 2017 10:21AM
So had to cut down the threaded shaft of the Subaru brake booster, even with the GSLSE brake booster spacer to get the pedal adjusted right. That said brakes are bled!
June 13, 2017 03:03PM
Brakes are bled..Great!
Do they work? Wha's the pedal feel like> Solid?
When you gonna drive it?
June 14, 2017 04:08PM
well trying to get the diff sorted out so that is a big issue. exhaust needs doing. Then some wiring and a good solid look over see what i've missed.
June 22, 2017 11:26PM
He's gotta stop putting shifters in BMW's and focus on the right priorities for the thing to ever run winking smiley
June 26, 2017 10:49PM
yea yea yea. I've been doing things.
Case in point!
The diff is in. 5.29 final drive with solid pinion sleeve and the Supra LSD with Weir kit. AND nothing is leaking after I added fluid. Horrah.
Related. The wheels fit. Which is good. Because wheels need to fit, or so I'm told.
Still working with the engine bay now. Need to finish some wiring, vacuum bits, the throttle linkage, some minor other things. More of a time issue at this point. The exhaust is the next big hassle.
deaner
Dane Aura
PS4 controller
June 27, 2017 07:37PM
Looking good!
July 06, 2017 12:27PM
Feckin awesome!
July 06, 2017 01:35PM
Feckin awesome!
it might even make noise some day soon!
July 25, 2017 10:17AM
it cranks!
a little more wiring and it should start.
That said, having issues fitting a muffler still. Might either have the RB muffler stick out the back farther and look a little stupid or hope that i find another option.
September 06, 2017 10:24AM
So the rx7 started.
September 06, 2017 02:51PM
And...............................................???
