Re: Rx-7 Rally Car v3.0!
June 21, 2014 01:20PM
one side is 14mm by whatever (course thread) and that is from the OLD hiem which we DONT want.
The inner tie rod for the Rx-7 is M12x1.25. No M14 anything. Forget you ever met Mr. 14.
2.75" length
5/8" 18 female on one side
M12x1.25 female on the other
OKie dokie that makes it a lot easier...That i have.
That tap i have here was 14 x 1.5 and down at the shop I have 14 x 1...
We'll just stick with 14 x 1.5 for manly wheel studs.
June 25, 2014 01:02AM
2.75" length
Adaptors done.
June 25, 2014 08:51AM
smiling bouncing smiley
June 27, 2014 12:00AM
Priority Mail...they say "Monday" but cross the fingers for Saturday..
Get that thing on the ground.
June 27, 2014 01:21AM
part of me wants to just say screw it and use the stock column and only have the 2.7 turns
June 27, 2014 01:56AM
2.7 should be "pretty damn good"
July 01, 2014 08:55AM
woo!
August 08, 2014 10:35AM
August 08, 2014 10:42AM
having no rear dampers = sinking like the titanic.
however, im mostly trying to show where the LCA mount to the subframe and if that is "too low" for ground clearance. Not that I can do much about it anyway...
August 08, 2014 11:30AM
Yes you can. Double thickness and fab a nice skid sloping forward.
or sumpin bwilliant.
"That which shall be smitten, that shall thee strengthen the fawk outta" John 11:35
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
August 08, 2014 11:57AM
Rally-America rules state that the longest an organizer can have competitors go between refueling is 90 miles. but there's no rule on how much of that can be stage vs transit .
so in theory they could have you do 90 miles of stage before a refuel.
12 gallons * 5 mpg = 60 miles ... hope you like pushing.... in all honesty the longest i can remember going before a refuel was the epic last year of jens Rally idaho . where we had a crazy long transit after a remote fuel , then a downhill stage that ended pretty much right at service.
I don't even think that was 60 miles. I know one of the desert storms had us going pretty far with out a refuel chance. 6 stages , 2 long transits and a few tiny ones + a turn around. might have been around 70 miles total ..
if you had a 15 gallon tank the chances of running out before a refuel go to basically zero.
August 08, 2014 12:23PM
im looking at the 15 to 16 gal mark if i cant get the stock tank to go back in nicely.
John, i was discussing that i can physically move them higher, but i shall skid the crap out of it.
August 08, 2014 01:34PM
does the normal ride height put the LCAs level (like the left side), or pointing up (like the right)?
left side doesn't look substantially lower than the LCA mounts on a civic, don't think I've heard any (impact related) issues with those. Granted on the Civic, the tank is right in front of them, on my car the skid plate covers the gas tank and the LCA mounts.
December 18, 2014 11:17PM
Stuff
open | download - IMG_3546361446967.jpeg (25.2 KB)
open | download - IMG_3513854308242.jpeg (31.3 KB)
open | download - IMG_3524052568080.jpeg (31.9 KB)
open | download - IMG_3527075370957.jpeg (34.3 KB)
open | download - IMG_3531723000376.jpeg (35.8 KB)
open | download - IMG_3536043532212.jpeg (23.6 KB)
Eric Ewert
Eric Ewert
volvo 240
December 18, 2014 11:23PM
You sir are very good at building rally cars. How does that toyota axle fit in the rx7 width wise? Also how did it compare in the weight department?
